1966 Mustang - rear seat belt mountings - Mustang Evolution
Old 07-24-2008, 02:14 AM   #1
I have a 66 Mustang Fastback which has front lap belts fitted.
As our car goes out on hire by families I am keen to install seat belts in the back as well for obvious safety reasons.
There are small slots in the corner of the rear seat as if to allow seat belts through the cushion. Does anyone know if there are seat belt mountings already fitted to the bodywork of a 66 Mustang?
Tony Merrygold
The Open Road
info@theopenroad.co.uk
www.theopenroad.co.uk
www.classiccarhireworld.com
theopenroad is offline   Reply With Quote
Old 07-24-2008, 06:20 AM   #2
Re: 1966 Mustang - rear seat belt mountings
i think there are bolt holes in the floor, for some reason i remember them being there last time i changed a set of floorpans.
SimplyOrange is offline   Reply With Quote
Old 07-24-2008, 07:15 AM   #3
Thanks, I'll check it out when I get a chance.
Tony Merrygold
The Open Road
Old 07-24-2008, 01:22 PM   #4
Herbstang's Avatar
65 and 66 had no rear seat belt holes unless ordered as a option
http://www.geocities.com/a65ragtop/V...tbelts_65.html
this article show you how to mount 3 pt seat belts Seatbelts
http://www.geocities.com/MotorCity/S.../seatbelt.html
Old 07-24-2008, 01:43 PM   #5
Herbstang's Avatar
Just spoke with a guy at work that has a 66 here's what he used to install rear belts Classic Ford Mustang Seat Cushions - Seat Belts - Hardware: 1965 1966 1967 1968 1969 1970 1971 1972 1973
Old 07-24-2008, 01:59 PM   #6
they must be a standard option on replacement pans, im pretty sure the last set i installed had holes in them.
Old 07-25-2008, 06:06 AM   #7
Herbstang's Avatar
You are correct !!!! I believe rear belts came standard starting in 67
Old 08-17-2008, 01:24 PM   #8
66Sprint200's Avatar
Then my mustang must have gotten them as options. My 66 has never had its floor pans replaced, but when we replaced the old belts we found that there where four sets of belts in the parts box in the trunk. the holes for mine were in the floor pan, just under the large opening between the rear back seat cushion and trunk. The 2 inner holes are just to the left and right of the transmission hump, and the outer holes where pretty much right behind the back corners of the bottom cushion. But you said yours was a fastback, and mine is the coupe/notchback. But still, I hope this helps.
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 08-17-2008, 03:03 PM   #9
I still haven't had time to look, but that makes me think it is definitely worth checking out.
I'll lt you all know what I find.
Thanks.
Tony Merrygold
The Open Road
1966 mustang
Seat belt issue MuStAnGcHIk88 Mustang Audio & Video 3 12-01-2007 12:41 AM
Seat belt hoop V6STANG007 Mustang Audio & Video 5 05-29-2005 03:31 PM
Lazy seat belt... SpectorV Mustang Audio & Video 13 12-24-2004 05:11 PM
Head Rest Removal/ Seat belt relocator cagedthought Mustang Audio & Video 14 12-04-2004 01:08 PM
Seat Belt Retraction tek55 Mustang Audio & Video 6 12-18-2003 08:44 PM
07:14 PM
