Help!! - Mustang Evolution
Old 05-19-2013, 01:46 AM   #1
Tyoung68's Avatar
Help!!
Soooo my car keeps dying. I need a jump every time i start my car. And my voltage gauge is only reading 11 when driving. Im not sure if i have me alternator hooked up right so any one with a l6 with a alternator not a generator post a pick of the back of it and what color wires come out would be really help full! But is my battery bad too? Or is it just because im not producing enough to charge my battery? Im at a loss i have a new regulator and all new wiring so thats not the problem
Old 05-19-2013, 09:55 AM   #2
rbohm's Avatar
ok first you should have between 13.5 and 15 volts when the engine is running, if not then likely you have a dead alternator. take the car to your local auto parts store and have them check the charging system, and do a load test on your battery as well.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 05-19-2013, 11:49 AM   #3
Tyoung68's Avatar
Its a new alternator
Old 05-19-2013, 12:20 PM   #4
rbohm's Avatar
that doesnt mean anything.
Old 05-19-2013, 01:38 PM   #5
Tyoung68's Avatar
That is very true! Haha ill take it ad see what they say
Old 05-19-2013, 05:32 PM   #6
Tyoung68's Avatar
My alternator is fine
Old 05-19-2013, 07:18 PM   #7
Commercial Member
matcox83's Avatar
Make sure your battery cable terminals are clean and you engine block ground is good.
Old 05-19-2013, 08:00 PM   #8
Tyoung68's Avatar
The grounds are all good battery was tested and is fine
Old 05-19-2013, 08:52 PM   #9
2stang's Avatar
double check grounds. block and chassis . check regulator , open reg can drain battery .
2stang is offline   Reply With Quote
Old 05-19-2013, 08:56 PM   #10
Tyoung68's Avatar
All grounds are good i know the wiring to alt was wrong
Old 05-19-2013, 10:23 PM   #11
Tyoung68's Avatar
so i found some wiring diagrams so is some one could tell me where the wires connect on their alt that would be great!!
Old 05-20-2013, 06:08 AM   #12
Commercial Member
matcox83's Avatar
Try this.
Old 06-04-2013, 03:20 PM   #13
Tyoung68's Avatar
Soo i still havent gotten it figured out... My battery and alternator have been tested and both passed i changed up my wiring and still nothing... If i unhook my battery while the car is running and it shuts off is the alternator suppose to support the engine ?
Old 06-04-2013, 06:20 PM   #14
rbohm's Avatar
yes the alternator should support the engine with the battery disconnected.
Old 06-04-2013, 06:29 PM   #15
Tyoung68's Avatar
So my wiring is wrong then?
Old 06-04-2013, 09:14 PM   #16
Commercial Member
matcox83's Avatar
Send us
---------- Post added at 11:14 PM ---------- Previous post was at 11:13 PM ----------
Originally Posted by matcox83 View Post
Send us
Post a picture of how you have it wired. Make it as clear as possible. Make sure the wire colors show.
Old 06-04-2013, 10:49 PM   #17
Tyoung68's Avatar
Well thats the problem its not factory wiring i got a painless wiring harness and all it had was a wire to go to the stator on the voltage regulator and thats it. I have all the wiring diagrams that i need for stock wiring i just cant decipher it
Old 06-05-2013, 05:53 AM   #18
Commercial Member
matcox83's Avatar
Does the Painless diagram give a description of what each wire does? Maybe we can compare to what the factory wires did.
Old 06-05-2013, 01:34 PM   #19
Tyoung68's Avatar
All it shows is a brown wire to the alternator
And this is what it says the brown wire is for
Old 06-05-2013, 01:34 PM   #20
Tyoung68's Avatar
Old 06-05-2013, 02:00 PM   #21
Aggiesrok's Avatar
You have an original multi-wire alt? They make a single wire newer one, that's probably what you need.
Old 06-05-2013, 02:36 PM   #22
Tyoung68's Avatar
Are one wires bad?
Old 06-05-2013, 07:55 PM   #23
Aggiesrok's Avatar
Originally Posted by travisb.young66 View Post
Are one wires bad?
No they're better put out more amps.
Old 06-05-2013, 08:06 PM   #24
Tyoung68's Avatar
What is a one wire? Just on wire going to the battery ?
Old 06-05-2013, 09:14 PM   #25
Aggiesrok's Avatar
http://item.mobileweb.ebay.com/viewi...d=360669036514
Try this link.
Old 06-05-2013, 11:40 PM   #26
Tyoung68's Avatar
I found one on summit
Old 06-06-2013, 07:56 AM   #27
Aggiesrok's Avatar
Cool. I'd go with Summit, I was just looking for an example.
Old 06-08-2013, 12:56 AM   #28
Tyoung68's Avatar
I got my alternator today and put it in its to late to drive it but i turned it on for a second and at 12 at my gauge.
Old 06-08-2013, 11:16 AM   #29
Aggiesrok's Avatar
Awesome, sounds good so far, hopefully you get running again.
Old 06-08-2013, 03:47 PM   #30
Commercial Member
matcox83's Avatar
12 volts is not charging. I don't think one wires work any different. You should be at 14 volts or more. Anybody know otherwise?
Old 06-08-2013, 04:45 PM   #31
Tyoung68's Avatar
Im at work now so i still havent drivin it but my battery is fully charged so i think thats the problem. Also when i gave it gas i had more volts charging
Old 06-08-2013, 05:08 PM   #32
Commercial Member
matcox83's Avatar
That's the part I don't know about one wires. Maybe they don't charge well at idle. It could be normal. Somebody with experience?
Old 06-08-2013, 08:34 PM   #33
rbohm's Avatar
some alternators dont put out much current at idle, usually the older ones dont.
Old 06-09-2013, 12:22 AM   #34
Tyoung68's Avatar
Its a new one wire? Does that effect it?
Also it doesnt have a regulator ? Should i have one?
Old 06-09-2013, 12:53 AM   #35
Aggiesrok's Avatar
What's it doing now? Have you driven it yet?
05:11 PM
