Wheel/ tire size - Mustang Evolution
Old 05-21-2013, 07:51 PM   #1
BA68 mustang's Avatar
Wheel/ tire size
Know that this topic gets beat to death but I can't find anyone who is running 235/ 15/ 60's on the front and 255/15/60's outback on 8" wheels... if anybody is backspacing and wheel info would be greatly appreciated
It's a 68 coupe
Thanks in advance
BA68 mustang is offline   Reply With Quote
Old 05-22-2013, 12:51 AM   #2
Tyoung68's Avatar
I know that for our cars its 00mm offset and 4.6 back spacing well at least thats what im running and the fit fine
Old 05-22-2013, 01:00 AM   #3
Tyoung68's Avatar
Well atleast thats what im running i have 17x8 with 235/50r17s on the rear and 215/45r17 on the front
Old 05-22-2013, 05:06 AM   #4
I know you can go up to 275's out back with 17s. Idk of I'm goanna have an issue with the upper ball joint in the front with 15's... My cars out for paint so I can't even check
Old 05-22-2013, 06:28 AM   #5
BigpapaDean's Avatar
I think you will be having problems with the ball joints in front...I'm gonna be running 16's with 245's all around and it's tight in front. 15's might be to small with that setup.
I'm assuming you got discs in front?
BigpapaDean is offline   Reply With Quote
Old 05-22-2013, 01:34 PM   #6
Tyoung68's Avatar
Yeah you might run into problems with 15s
Old 05-22-2013, 07:43 PM   #7
I have 4 wheel drums at the moment but I plan on putting 67 style discs up front
Old 05-22-2013, 08:06 PM   #8
Tyoung68's Avatar
You can always grind down the uca a little i had to do that on mine
Old 05-23-2013, 07:36 AM   #9
That's what I'm doing, original 4piston disc setup. Like I said, it's a tight fit on 16's.
Old 05-23-2013, 04:17 PM   #10
Hmmm.... What backspacing/wheels?
Old 05-23-2013, 04:46 PM   #11
Not sure about the specs but these are the rims i'm gonna be using...minus the big ugly tires! Lol
ID:	109955   Click image for larger version
Old 05-23-2013, 06:05 PM   #12
Aggiesrok's Avatar
Here's a guide I found for classics
Old 05-23-2013, 06:07 PM   #13
Aggiesrok's Avatar
It's a PDF, probably can only see it on a computer. Sorry about that, it's pretty comprehensive.
Old 05-23-2013, 06:41 PM   #14
Is that the one from dodgestang?
Old 05-23-2013, 07:37 PM   #15
Aggiesrok's Avatar
Yes it is.
Old 05-24-2013, 05:54 PM   #16
Okay.... That's the one I've been looking at but I didn't know how reliable it was
04:35 AM
