73 Mach 1 - Mustang Evolution
Old 06-21-2013, 11:46 AM   #1
03RedfireGt's Avatar
73 Mach 1
My wife's uncle has a 73 Mach 1fastback he said he will sell us for $300. It has no interior, engine, or trans. The body is solid with no rust. I am planning on swapping the 03 from 2v to 4v next year anyways, so is it possible to put the 2v in the 73? He has 351 he will give us with the car it needs a rebuild.
03RedfireGt is offline   Reply With Quote
Old 06-21-2013, 12:02 PM   #2
MidnightBlueGT's Avatar
Any swap is possible its the amount of fabrication you're willing to do.
Old 06-21-2013, 12:59 PM   #3
alrefire's Avatar
If you're looking to do the swap, I forgot the company's name. but they make IFS kits for 64-73 models. and in those kits, you can choose which motor mounts you want. they have them for several engines. you might want to check it out.
---------- Post added at 01:58 PM ---------- Previous post was at 01:57 PM ----------
found it!!!
Mustang Rod & Custom Rack and Pinion/Disc Brake Conversion Kit With Coilover/Tubular A-Arm System Manual Steering V8 1965-1973 | CJ Pony Parts
---------- Post added at 01:59 PM ---------- Previous post was at 01:58 PM ----------
you can also look around, there are some for manual/power steering and manual/power brakes.
good luck!!!!
02:19 AM
