5 lug conversion - Mustang Evolution
Old 07-09-2013, 03:02 AM   #1
austinknoll's Avatar
5 lug conversion
I'm looking around for a 5 lug conversion for my 65' coupe. What all is needed to convert? maybe a kit? Also will be converting them to disc brakes all around.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-09-2013, 01:25 PM   #2
renouji's Avatar
Region: Utah
Send a message via Yahoo to renouji Send a message via Skype™ to renouji
one question, why would you want to convert to 5 lug?
-Just so I understand.
renouji is offline   Reply With Quote
Old 07-09-2013, 01:29 PM   #3
Stronger and better brake and wheel selection
Old 07-09-2013, 02:44 PM   #4
Exactly. I want to throw on some bullitt rims and the power I'm planning on putting down, I think 5 lug would be better. I just can't seem to find a conversion for the front axle. I plan on swapping the rear to a ford 9" with 5 lug so that shouldn't be a problem but the fronts are my problem
65 Mustang coupe
Old 07-09-2013, 04:00 PM   #5
gc19662007's Avatar
My research led me to 70s Granada parts for 5 lug and disk brakes before I decided to go with a full new modern front end. Im sure there is other input here from experience, mine was only research for my 66 at the time.
I also did a lot of looking at CJPONYPARTS, Mustangsunlimited and a few mustang part places I've seen on this site. You'll get a lot of good advice and direction here.
gc19662007 is offline   Reply With Quote
Old 07-09-2013, 04:57 PM   #6
Tyoung68's Avatar
I did a five lug swag i got a 8.8 in from a 67 and got a wilwood kit and k can stop on a dime i also got a brake booster but that isnt needed i had 4 lug drums in the front and my kit bolted right on
Old 07-09-2013, 11:39 PM   #7
Do you have the links to the kit? With the 302 I'm putting in I'm gonna need disc brakes haha
65 Mustang coupe
Old 07-09-2013, 11:54 PM   #8
Tyoung68's Avatar
Im on my phone right now but just go look at summitracing.com and just search for wilwood youll be able to find the kits i think my was around 750
Old 07-10-2013, 01:37 AM   #9
renouji's Avatar
Region: Utah
do you think I should convert my wheels to 5 lugs? I'm running a modified 302, I have no idea what is under the hood other than it has edelbrock carb, manifold and air intake and has a 5 speed transmission pulled from a sunbeam.
Old 07-10-2013, 01:50 AM   #10
Tyoung68's Avatar
You should convert to disk if you dont have them
Old 07-10-2013, 11:54 AM   #11
Commercial Member
matcox83's Avatar
Renouji's profile says Mustang II so the fronts would be easy to switch to 5 lug but I dont know about the rears. He doesn't have the options that 60's 4 lug cars have.
Any of you new Mustang II guys have any ideas? Built 9" is probably not an option!
Old 07-10-2013, 05:18 PM   #12
I found the wilwood kits on summit. Are they all 5 lug conversions?
65 Mustang coupe
Old 07-10-2013, 05:23 PM   #13
Tyoung68's Avatar
Umm i think but the bolt spacings are different
Old 07-18-2013, 11:34 AM   #14
What did you do with your rear axle?
65 Mustang coupe
Old 07-18-2013, 01:14 PM   #15
Tyoung68's Avatar
I swapped it out for a 8in out of a 67
Old 07-18-2013, 01:21 PM   #16
Tyoung68's Avatar
They pop on cl all the time around me
Old 07-18-2013, 02:09 PM   #17
Did it bold right in? Did you have to do any fab?
65 Mustang coupe
Old 07-18-2013, 02:12 PM   #18
Tyoung68's Avatar
Yeah bolted right up. My drive shaft fit and everything
Old 07-19-2013, 07:29 PM   #19
I'm looking at these wilwood kits and they look pretty good but say they're designed for 5 lug V8 models. It looks like it just bolts up to the stock 4 lug spindle but I'm not sure. You're bolted up fine though right?
65 Mustang coupe
Old 07-19-2013, 09:04 PM   #20
Tyoung68's Avatar
Yeah the kit i got had 2 bolt patterns on it one for the stock disks and one for the stock drum. It was a little tricky to get everything the right way but its wasnt to hard
Old 07-24-2013, 04:37 PM   #21
rbohm's Avatar
in order to do a five lug conversion on a 65-66 mustang, you must replace the six cylinder spindles with V8 ones. the six cylinder spindles are smaller than the V8 spindles. you can use the 67-70 spindles as they are the right size and bolt in. you just then use the needed hubs, bearings, brakes, etc. all the parts are available from a variety of places. i believe master power brakes has a complete kit including the proper spindles for around $1000.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 07-27-2013, 11:47 PM   #22
Ok I've seen kits that you can install that do not require the use of a v8 spindle. They utilize the stock spindles but convert it to a 5 lug wheel
65 Mustang coupe
Old 07-28-2013, 12:08 AM   #23
rbohm's Avatar
link?
Old 07-28-2013, 08:49 AM   #24
Commercial Member
matcox83's Avatar
This is just the first one I came across. A lot of places sell the kit.
http://www.lamustang.com/ShowItem/10...205%20Lug.aspx
Old 07-28-2013, 09:43 AM   #25
rbohm's Avatar
nice, i bookmarked the page. thanks.
Old 09-17-2013, 01:22 AM   #26
Starting up the thread again but why does everyone say convert to v8 spindles? The spindles online don't have the studs for the wheel. Are they stronger or something?
65 Mustang coupe
Old 09-17-2013, 11:56 AM   #27
rbohm's Avatar
for a very long time there were no conversion kits to convert the pre 66 six cylinder spindles to five lug, and the pre 66 spindles are in fact weaker than the V8 spindles. these days the issue is less clouded as most people that want five lug wheels are going to keep the six, and are generally not high performance cars so stresses on the spindles are not as great as if you installed a V8 and lots of power.
07:58 PM
