302 V8 engine knocking. - Mustang Evolution
Old 07-09-2013, 11:21 AM   #1
zodo27's Avatar
Region: Utah
My engine is knocking really bad on my 78 stang what are the possible problems and solutions? It's not a rod I had all of those checked and they were all straight. And I just had the fuel and oil pump replaced as well. Any ideas?
zodo27 is offline   Reply With Quote
Old 07-09-2013, 12:07 PM   #2
Don't ever assume anything about an engine. They work great right up until the moment that they don't work. When you say "knock" I generally associate that with a bearing noise coming from the bottom of the engine, I.e. rod bearing. Why did you replace the oil pump? Try to determine approximately where the noise is coming from...
Old 07-09-2013, 12:25 PM   #3
zodo27's Avatar
Region: Utah
I asked my mechanic and he said that it might need a new engine block I was just looking for a second opinion. He said a new block would be cheaper than a rebuild
Old 07-09-2013, 12:35 PM   #4
He is absolutely correct. Not as good as a meticulously built rebuild but a crate engine is way more economical. Luckily for you, 302's are dime a dozen. You should have no problem finding a good deal on one. Try craigslist.
07:50 AM
