Radiator help! - Mustang Evolution
Old 07-21-2013, 03:53 PM   #1
Radiator help!
So I'm guessing I need a new higher capacity radiator to keep my 67 mustang cooler, but I don't have 300-600 to spend on one, what should I get and is there any I could get at a scrap yard that will fit?
93stang306 is offline   Reply With Quote
Old 07-21-2013, 09:48 PM   #2
Aggiesrok's Avatar
What do you have now? 2-row? How hot is it running? Could be some other issues. You might be able to get a rebuilt one from radiator shop
Old 07-22-2013, 10:39 AM   #3
Yes I believe it's a 2 row and it boiled over once already I have a 160 thermostat and water is flowing throw the radiator good I took The cap off and can see it flowing.
Old 07-22-2013, 06:57 PM   #4
Aggiesrok's Avatar
Boiled over, through the cap? You need a 3 or 4 row. Do you have the heater core hooked up? What coolant mix are you using?
Old 07-26-2013, 07:19 AM   #5
Deerslayer's Avatar
We are in Austin with many 100+ days with the worst traffic in the Nothern Hemisphere. I have had to do PLENTY with our '65 to get it to operate and cool with these conditions. Dont get so obsessed on rows, but on the SIZE of the tubes in the radiator. A 4 row with small tubes can be more inefficient than a 3 row with larger tubes. FIRST thing I would try if I were you on your budget is to get a a good fan shroud. This can make a BIG difference if you are overheating when at a stop. If your car cools o.k. while driving, but heats up significantly while in traffic, try a good shroud first and see if that helps.
Here is what I ended up doing to make it bulletproof:
High Eff. 3 Row Aluminum Radiator
High Flo water pump
3" Fan Shroud
180* thermostat
Water Wetter added
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
01:20 PM
