Upgrading to 302 - Mustang Evolution
Old 08-08-2013, 04:06 PM   #1
Region: New Hampshire
Upgrading to 302
Currently running inline6, bought a 302 block and buying a c4 transmission . My question is should i or not upgrade the frontend ,or is the inline suspension which is new ,good enough ? Will the 4 lug rearend stand up to the power of the 302, which when im done the engine will push 400+ hp. Suggestions appreciated Ty .
kevin66 is offline   Reply With Quote
Old 08-08-2013, 04:11 PM   #2
Stanglover1966's Avatar
I'd upgrade but the stock front CAN work, albeit not very well.
Stanglover1966 is offline   Reply With Quote
Old 08-08-2013, 07:44 PM   #3
iStang65's Avatar
Region: Alaska
UPGRADE. Everything equipped for an i6 isn't meant to handle the weight and power of a v8. Spindles definitely need to be swapped to v8 along with everything suspension wise especially your coil springs since the new weight of the 302 will weigh down on the i6 springs
iStang65 is offline   Reply With Quote
Old 08-09-2013, 07:08 AM   #4
LukeRailey68's Avatar
You need to upgrade brakes before anything.
LukeRailey68 is offline   Reply With Quote
Old 08-09-2013, 10:09 AM   #5
Commercial Member
matcox83's Avatar
The suspension components, except the springs are the same. The steering components, including the spindles are the difference. Your rear end will explode almost when you drop it in drive if you try to put 400 hp through it! Seriously though you'll want 5 lug all around. So an 8 will be fine for now. Don't forget exhaust, radiator, and V8 fuel line. Engine wiring harness is different too. Throttle linkage. Drive shaft. Lots of threads in the forum that list everything you'll need to do. Do it right and make it safe.
Old 08-09-2013, 11:32 AM   #6
Tyoung68's Avatar
I upgraded all my suspension stuff but my springs before im getting my v8 im almost there just need to get some sway bars and v8 springs but after that ill be set. I got 8in rear end power brakes and disk brakes on the front and all new brake lines along with all new bushings and an adjustable proportioning valve
Old 08-10-2013, 01:39 PM   #7
austinknoll's Avatar
No upgrade to 5 lug disc brakes all around and buy at least an 8" to hold the power but preferably an 8.8 or 9"
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 08-10-2013, 02:14 PM   #8
Tyoung68's Avatar
You dont need disk all the way round drums on the rears are fine i have no problem stoping
06:42 AM
