Instrument panel issues? - Mustang Evolution
Old 08-10-2013, 11:22 AM   #1
renouji's Avatar
Region: Utah
Send a message via Yahoo to renouji Send a message via Skype™ to renouji
So none of my gauges seem to be working right on my 1978 Mustang II. My Tach bounces all over the place, my speedometer bounces around between 10-30 mph no matter how fast I am going, my fuel guage always reads 1/4 of a tank over full no matter how much gas is in the tank, nothing else works either including the lights for the dash. I am at a loss obviously everything is getting power, any advice would be welcome.
renouji is offline   Reply With Quote
Old 08-10-2013, 12:02 PM   #2
Aggiesrok's Avatar
Speedo could be a spring or the gear in the trams or the cable is unraveled. Fuel could be the sending unit in the tank or you could have a bad voltage regulator in the panel. You'll have to make sure you're getting the right voltage and proper grounding to the instruments, then diagnose each gauge individually. Also check each sending unit and the wiring.
Old 08-10-2013, 12:08 PM   #3
renouji's Avatar
Region: Utah
Someone else was saying its prolly the voltage regulator too, how do I diagnose each guage? any good tutorials online?
Old 08-10-2013, 09:00 PM   #4
Aggiesrok's Avatar
There was an article in mustang monthly. I'm not sure when, but you can google it and find it. It goes through pretty good detail.
Old 08-12-2013, 07:34 PM   #5
go501green's Avatar
To check the sending unit you can take the single wire of the unit, stick a screw driver in it and ground it to something. If the needle on the gauge moves then it's the sending unit. If the needle doesn't move it's the gauge.
go501green is offline   Reply With Quote
04:20 AM
