Loose steering. 66 coupe. - Mustang Evolution
Old 08-11-2013, 07:04 AM   #1
richpickins01's Avatar
Being very new to driving an American classic I wondered if it is normal in having so much play in the steering. I have changed the tie rod ends which has helped a little but i wondered if there was anything else i could do to really tighten things up. New fast ratio steering box maybe? Thanks
richpickins01 is offline   Reply With Quote
Old 08-11-2013, 07:58 AM   #2
Commercial Member
matcox83's Avatar
A new or rebuilt steering box will fix your problem. I converted to a power steering setup from Borgeson. Pretty easy to install except the steering column modification. I have no regrets doing it on my '66. You can also consider rack and pinion for more "spirited" driving.
Old 08-11-2013, 08:39 AM   #3
When i get a bit of money saved i think i will do the same but good to know its fixable matey.
Old 08-11-2013, 09:53 AM   #4
Aggiesrok's Avatar
The idler arm can have a lot of play. I just changed it out with the tie rod ends and it helped a lot. It's fairly cheap and easy.
Old 08-11-2013, 10:02 AM   #5
I will look it up. Not sure which part that is. But top tip thanks
Old 08-12-2013, 07:31 PM   #6
go501green's Avatar
Not sure how much a new one costs but you can probably get a manual steering box rebuilt for $150-200. Which may solve your problem.
go501green is offline   Reply With Quote
Old 09-25-2013, 11:28 AM   #7
As a cost free short term fix I just tightened the bolt on top of the steering box which did the trick
Old 09-26-2013, 12:05 PM   #8
Tyoung68's Avatar
Be carful not to over tighten that i did and broke the gear in the box
Old 09-26-2013, 01:09 PM   #9
What happened. Did you notice straight away? Dont want to be driving along and it goes on me :/
Old 09-26-2013, 01:51 PM   #10
Tyoung68's Avatar
Well the steering wheel was really hard to move my box was really worn how many turns did you do?
Old 09-26-2013, 02:04 PM   #11
Honestly. I did a 10th like advised and it did sod all then another couple. It wont go any further haha but god did it help.
Old 09-26-2013, 03:21 PM   #12
Tyoung68's Avatar
Hmm idk haha i was pulling into a driveway when i broke mine i was really cranking on it
Old 09-27-2013, 07:07 AM   #13
****tt. At least it wasn't while driving along man. One day I.ll get a new box and do all the bushes so its nice and tight.
Old 09-29-2013, 02:01 AM   #14
Tyoung68's Avatar
Good idea. I did that and my car handles like a dream !
Old 11-09-2013, 08:33 PM   #15
Getn off's Avatar
My 67 was loose for years. Simple alignment cured it! Embarrassing.
Troy
Getn off is offline   Reply With Quote
06:09 PM
