Master Cylinder Help - Mustang Evolution
Old 08-17-2013, 07:51 PM   #1
MG1969Coupe's Avatar
I need one more fitting for my master cylinder and I can't find it anywhere! I need one with a 9/16-18 female end and a 3/8-24 male end. It seems impossible to find. I could also make it work with a fitting that has a 1/2 female end and a 3/8-24 male end. Anyone know where I can purchase any of these fittings?
MG1969Coupe is offline   Reply With Quote
Old 08-17-2013, 08:31 PM   #2
Commercial Member
matcox83's Avatar
Try Jegs.
http://www.jegs.com/s/customercare/contacts.html
---------- Post added at 10:31 PM ---------- Previous post was at 10:30 PM ----------
Originally Posted by matcox83 View Post
Call or email them. They are better at finding stuff.
Old 08-17-2013, 08:34 PM   #3
Try Jegs.
I will call them right now thanks. If all else fails and I can't find one of the 2 that I need can I just connect three adapters together to get to the size I need? I need to go from a male 9/16-18 brake line to a 3/8-24 female end in my new mast cylinder. Could I just get a fitting with a female 9/16-18 to connect to the 9/16-18 brake line and this fitting has a 1/2-20 male end. Then use a fitting with a 1/2-20 female and 7/16 male. Then finally a 7/16 female to a 3/8-24 male? Get what I am trying to say?
Old 08-17-2013, 08:52 PM   #4
Commercial Member
matcox83's Avatar
Yes. As long as you have room for it and tighten them correctly. Hopefully Jegs or someone can fix you up. I never got stumped by brass fittings on my car because I had a local store with a great inventory. Remember you can use elbows if you have to make room.
Old 08-17-2013, 10:15 PM   #5
Ok thanks. Here is a link to a chart of fittings napa has.
http://www.napabeltshose.com/~/media...sFittings.ashx
Do I have to use fittings under the "Dual Master Cylinder Adapter" category? Or can i use some from the "Male Pipe to Female Inverted - Brass" section
Old 08-18-2013, 06:25 AM   #6
Commercial Member
matcox83's Avatar
As long as the fittings are the right type, it doesn't matter. If you can work with Napa it might be better because you can show them what you need.
Old 08-19-2013, 12:15 AM   #7
Tyoung68's Avatar
Make your own line with the right fittings its pretty easy just need a double flaring tool and a tubing bender i made all new lines for my car
Old 08-19-2013, 10:31 PM   #8
Yea I just did that this past weekend. Thanks
03:28 AM
