Lowered classics? - Mustang Evolution
Old 08-21-2013, 10:32 AM   #1
Tyoung68's Avatar
Lowered classics?
I have a 68 and want to know two things what was stock ride hight and where do i measure from. And if you are lowered what are you lowered on and what tires? Im looking to lower my car and i already screwed up on rear tire by rubbing
Old 08-21-2013, 01:35 PM   #2
Aggiesrok's Avatar
Where is it rubbing and when?
Old 08-21-2013, 02:11 PM   #3
Tyoung68's Avatar
On the quarter i already folded the lip over but that was after i took a chunk out of my tire
---------- Post added at 01:11 PM ---------- Previous post was at 01:11 PM ----------
And its on big bumps
Old 08-21-2013, 11:18 PM   #4
Aggiesrok's Avatar
What's the tire size?
Old 08-21-2013, 11:25 PM   #5
Tyoung68's Avatar
235/50r17
Old 08-22-2013, 08:48 AM   #6
Aggiesrok's Avatar
235/50r17
Have you thought of 235/45/17? That would give you a 1" reduction in overall tire height.
Also what's the back spacing on your rims? It should be around 4"- 4 1/2". If you have less than that, it moves the wheel towards the fender.
Old 08-22-2013, 10:05 AM   #7
Tyoung68's Avatar
Im actually running those on the fronts i wanted the staggered look but i couldnt get different sized rims so did it with the tires i will get smaller tire when these wear out
Old 08-22-2013, 02:23 PM   #8
Aggiesrok's Avatar
It could be your backspacing.
Old 08-22-2013, 03:19 PM   #9
Tyoung68's Avatar
I have 00mm on both that is what i was told to get from tire racki could get different backspacing but that would mean i have to get different rims
Old 08-22-2013, 05:28 PM   #10
Aggiesrok's Avatar
So your rims have zero backspacing? That's why your tires are hitting the lip.
Old 08-22-2013, 08:10 PM   #11
Tyoung68's Avatar
I wonder if i could machine some off my rim of on a mill?
Old 08-22-2013, 08:54 PM   #12
Aggiesrok's Avatar
They might have been talking about offset and not backspacing. Which totally different.
Old 08-23-2013, 12:45 AM   #13
Tyoung68's Avatar
Ha oh wait im talking offset not backspacing haha i forget what my backspacing is
Old 08-23-2013, 08:14 AM   #14
Aggiesrok's Avatar
No problem. It's the distance from the back of the rim to the bolt holes. 60's mustangs should be around 4 to 4 1/2 inches depending on wheel diameter. There are a few charts on the Internet for each model and wheel size. If you gave an 8" rim and 0 offset then you're good.
Old 08-23-2013, 11:56 AM   #15
Tyoung68's Avatar
I know what backspacing js i just forgot what my backspacing i have on my rim and that is what i have
Old 08-23-2013, 01:46 PM   #16
Aggiesrok's Avatar
Sorry didn't mean to imply anything.
Old 08-23-2013, 01:49 PM   #17
Tyoung68's Avatar
Oh don't worry about it haha you're just trying to help me
06:44 AM
