1968 Project Car - Mustang Evolution
Old 08-22-2013, 03:03 PM   #1
RocknCali's Avatar
1968 Project Car
I'm looking to purchase a 1968 mustang here in the near future.
But here is where I come to you guys/gals.
I want it to be my DD.
I want it to look original; but be state-of-the-art underneath.
So from my limited knowledge that would mean new rearend, driveshaft, suspension, tranny, and new F/I engine.
Has anyone done this on here and any tips or advice or possibly something I may have left out?
RocknCali is offline   Reply With Quote
Old 08-22-2013, 03:36 PM   #2
1lowGT's Avatar
Better find you a good chassis or this will take forever. Google this and you'll find stuff. You should just build a NA motor
Old 08-22-2013, 04:52 PM   #3
RocknCali's Avatar
NA motor? sorry new to car forum lingo
Old 08-22-2013, 04:54 PM   #4
1lowGT's Avatar
Lol it's cool. Naturally aspirated. No super/turbo charger.
Old 08-22-2013, 04:56 PM   #5
Ubnbit's Avatar
R u looking for a 6 or 8 car?
Old 08-22-2013, 06:23 PM   #6
RocknCali's Avatar
OHH haha I meant fuel injected. I'm assuming F/I on here means forced induction
---------- Post added at 05:23 PM ---------- Previous post was at 05:23 PM ----------
cylinder size?
Old 08-22-2013, 07:58 PM   #7
1lowGT's Avatar
Yeah we say fi as forced induction. Efi for fuel injection. Ubnbit means v8 or 6
Old 08-22-2013, 08:09 PM   #8
Tyoung68's Avatar
If you start out with a v8 car you wont need a need a new rear end and the other suspension parts and start with a clean body that was my biggest mistake
Old 08-22-2013, 09:00 PM   #9
RocknCali's Avatar
oh! yes thanks for the heads up
Old 08-23-2013, 04:56 AM   #10
Ubnbit's Avatar
Yep and guys like Travis will be a huge asset to u during a build.
Definitely start with a v8 car. The conversion from a 6 to an 8 car alone can suck. Remember 302's are plentiful. Make sure before u buy, u look under it. It's the stuff that's not visible that will get u.
Old 08-23-2013, 08:07 AM   #11
RocknCali's Avatar
so go for a 302 not a 289?
Old 08-24-2013, 09:26 PM   #12
Tyoung68's Avatar
I dont know if there was a difference between a 302 and 289 if there was it just be the coil springs
Old 08-24-2013, 09:49 PM   #13
Aggiesrok's Avatar
I think the only difference is the stroke 2.87 on 289 and 3.00 on the 302. Both have 4" pistons. Everything else should bolt up to either.
Old 08-24-2013, 09:54 PM   #14
Tyoung68's Avatar
I was talking suspension haha
Old 08-24-2013, 10:20 PM   #15
Aggiesrok's Avatar
Sorry. I keep misreading everything.
Old 08-24-2013, 10:34 PM   #16
Tyoung68's Avatar
Ha no problem!
Old 08-25-2013, 08:07 AM   #17
AgentOrange's Avatar
My recommendation is a drive train out of an early Fox body. All necessary T-5 conversion parts are available on the market, adapting to a cable clutch is simple with the right parts, and you can make a carb'd 302 scoot that light car with just a little work. As far as making the suspension modern, it wouldn't be worth the money spent modifying everything. Best off buying the best direct replacement performance stuff you can afford.
AgentOrange is offline   Reply With Quote
Old 08-25-2013, 10:57 AM   #18
RocknCali's Avatar
thanks for the input on the suspension. I'll def look further into it
Old 08-25-2013, 12:05 PM   #19
Tyoung68's Avatar
Iv have the shelby drop and roller spring perches with all polly bushings and my ca handles pretty good a little body roll but i dont have a sway bar on my rear
Old 08-25-2013, 12:38 PM   #20
alrefire's Avatar
If you want modern suspension,
Swap your front suspension with an IFS, and rear with a watt's link
The biggest thing, for a DD is power steering, and disc brakes (as far as condition you buy it in, if you're buying just a body, then look for a good body that had a v8 in it)
Also make sure it's 5 lug, make it a lot easier when it comes to wheel choice
Old 08-25-2013, 04:03 PM   #21
Tyoung68's Avatar
My mustang is my dd and i dont have power steering its is a bitxh but still it isnt bad but power disk is pretty important
Old 08-25-2013, 05:04 PM   #22
alrefire's Avatar
You can always add power steering :p
For 700 XD
Old 08-25-2013, 05:14 PM   #23
RocknCali's Avatar
For 700 XD
is it fairly simple to add?
Old 08-25-2013, 06:17 PM   #24
alrefire's Avatar
Idk I haven't done it :p
Old 08-25-2013, 06:53 PM   #25
Tyoung68's Avatar
I believe so there are kits that just bolt right up
Old 09-12-2013, 07:19 PM   #26
BudmanAk's Avatar
Region: Alaska
Does anybody have a link to look into a power steering kit for my 1968 Coupe?
BudmanAk is offline   Reply With Quote
Old 09-12-2013, 07:29 PM   #27
Look into a "Borgeson Box" kit. I know NPD carries them.
Old 09-12-2013, 07:46 PM   #28
BudmanAk's Avatar
Region: Alaska
NPD?
Thanks for the reply
Old 09-12-2013, 07:50 PM   #29
NPD?
National Parts Depot. A google search will yield a lot of the information you want faster than a forum. That being said, the Borgeson Box is a GM style PS setup. It will give steering assist even at low RPMs, unlike factory setups.
Old 09-12-2013, 07:54 PM   #30
Tyoung68's Avatar
Or you can look into a rack and pinion style
Old 09-12-2013, 07:57 PM   #31
BudmanAk's Avatar
Region: Alaska
Thank you for the info.
I'm off to check this out!!
Old 09-22-2013, 01:20 PM   #32
O468Mustang's Avatar
thanks guys... i am just trying to figure this out too..i want a new dirty project.. prefer the 68 -v8...i am a dreamer..but i have time..well, i will MAKE it..for this...
any suggestions?
O468Mustang is offline   Reply With Quote
Old 09-22-2013, 05:46 PM   #33
Tyoung68's Avatar
Originally Posted by O468Mustang View Post
thanks guys... i am just trying to figure this out too..i want a new dirty project.. prefer the 68 -v8...i am a dreamer..but i have time..well, i will MAKE it..for this... any suggestions?
Get a car with the least amount of body work and if all you can find is a l6 then its not to bad to swap it all over for a v8
Old 09-24-2013, 10:43 PM   #34
Bpolley11's Avatar
I got brand new suspension for my 68, rides rougher than the older worn out suspension. Partly might be because it was lowered one inch and I went from 15 to 17 inch rims so my tires weren't as thick but it still seems a little rough for having bought brand new suspension.
Bpolley11 is offline   Reply With Quote
Old 09-24-2013, 10:53 PM   #35
Tyoung68's Avatar
Did you get all stock suspension?
08:57 PM
