Rear end help - Mustang Evolution
Old 08-25-2013, 03:38 PM   #1
austinknoll's Avatar
Rear end help
Will a 8" out of a 72 mustang fit my 65? I has disc brakes and 3.0 gears.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 08-29-2013, 01:51 PM   #2
Tyoung68's Avatar
As long as where the springs sit and the then length are the same
Old 08-30-2013, 10:19 PM   #3
Stanglover1966's Avatar
I doubt it. Your best bet is a 9" from a ranchero
Stanglover1966 is offline   Reply With Quote
Old 08-31-2013, 08:10 AM   #4
Commercial Member
matcox83's Avatar
Rear springs are the same design for all first generation so the pins would be good. Compare the width of the housings from flange to flange. I'm with Travis, I think you'll be OK. But measure first. '72 is pretty specific so I guess you already have a line on the axle?
Old 09-05-2013, 12:15 PM   #5
Yeah I was talking to a guy but my dad fist want to get it yet so he sold it. So all rear end setups for first gen mustangs are the same? Correct?
65 Mustang coupe
Old 09-05-2013, 01:58 PM   #6
Commercial Member
matcox83's Avatar
Spring rates differ but the size and shape of the spring itself are the same. Shock mounting plates and u bolts can differ due to some axle housing tube diameter differences, so get them too if you do the swap. Shocks were also the same size but could be tuned differently.
Old 09-06-2013, 12:45 PM   #7
Streetfighter's Avatar
Region: Iowa
as long as ur still in need of a new rear axle i definitely recommend the 8.8 out of a fox body! me and my dad got one that was already pozi with 4.10s and some even come with disks and they are relatively cheap cuz there are so many of them out there there is some fab work to be done if you want to run one tho here is a link that shows what you have to do
The Ford 8.8 Mustang Rear End - Car Craft Magazine
---------- Post added at 01:45 PM ---------- Previous post was at 01:45 PM ----------
Streetfighter is offline   Reply With Quote
Old 09-07-2013, 11:11 PM   #8
rbohm's Avatar
no the rear end from a 71 mustang will NOT fit a 66 mustang unless you narrow it substantially. as for the fox body rear end, it can be made to work after all the fox brackets are cut off and new leaf spring perches welded on.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
08:12 AM
