Interior - Mustang Evolution
Old 09-14-2013, 10:30 PM   #1
Interior
I need detailed pictures of an older mustang dash like 65-67 and measurements if possible
Ronnysbray is offline   Reply With Quote
Old 09-14-2013, 10:38 PM   #2
Aggiesrok's Avatar
Here's a 67 with Autometer gauges. What info are you looking for? I've got a blank instrument panel, that I could measure some stuff on.
Old 09-14-2013, 10:45 PM   #3
Well you see im building an 89 ford ranger right now with a 302 and at first i was gonna do a 2005+ dash in it and and ive came to the conclusion id much rather have a simplistic older style mustang dash in her so i need pictures of the whole dash every inch of it and measurements like the gauge sizes and the length and width of the dash just to see what all ill have to do to get this in im also planning on doing older mustang peddles in it.
Old 09-18-2013, 06:59 PM   #4
DaddyO's Avatar
Here is my 66 GT coup dash. I have some others when the dash was stripped clean before I put the new wiring harness in.
ID:	129456   Click image for larger version
DaddyO is offline   Reply With Quote
Old 09-18-2013, 07:23 PM   #5
how long is the dash in inches? I really want to do an old mustang interior on it i know ill have to do some fab work on it but this ranger is going to be built for show/drag and i love the simplistic yet stylish look of the old mustang interiors i just need to find a dash, steering column and pedal assembly i would love to get a shifter from one
Old 09-18-2013, 08:11 PM   #6
DaddyO's Avatar
I think it's 52 1/2 inches between vent windows
ID:	129463   Click image for larger version
Old 09-19-2013, 06:51 AM   #7
Thank you i will measure today when i go out to my shop you wouldnt happen to know how long the steering column is do you? also do the have power brakes? If so could you measure the breakbooster for me if i don't end up getting a complete aftermarket one from summit what size are the stock gauges in the mustang?
---------- Post added at 06:51 AM ---------- Previous post was at 06:49 AM ----------
also what is the diameter of the steering wheel? whats the depth of the glove box? luckely i have a junk yard not to far from here with rows and rows of classic mustangs and camaros there so im hoping i can get the parts i need there
Old 09-19-2013, 11:04 AM   #8
Commercial Member
matcox83's Avatar
If you have a yard that close, you should head over there with your tape measure. You will get more ideas for measurements while you're looking at one. The '65/'66 steering column is a simple tube that surrounds a shaft that is integral to the steering gear, so you will likely be fabricating that anyway. You do realize the dash is welded in on an old one, right? You won't be able to just unbolt it and make it fit. How are your skills? It does sound like it would look great.
Old 09-19-2013, 11:10 AM   #9
Ive been building cars since i was 12 the yard is a good 30-40 miles away and cutting and welding aint no problem my ranger is completely bare i currently need to do alot of welding on the interior i have pictures of it posted on here on my profile
Old 09-20-2013, 09:57 AM   #10
Commercial Member
matcox83's Avatar
Lets see, at $3.50/ gal that could be an expensive trip just for measurements! I'll see if I can take some quick ones tonight or tomorrow if you don't get any other responses. Check online for instrument cluster bezels and clusters, I think there are some designed for aftermarket gauges.
There's a whole series of these 6 gauge ones but they are complete with gauges:
http://www.cjponyparts.com/new-vinta...66/p/IBC653-V/
Old 09-20-2013, 12:35 PM   #11
ER12883's Avatar
Have you narrowed down which year(s) you are looking at? If you like, I can get some measurements of my 67 tonight.
Evan
ER12883 is offline   Reply With Quote
Old 09-20-2013, 03:27 PM   #12
yeah it would be an expensive trip lol just for measurements and if worse comes to worse ill mold a mock up of one if size doesnt match up and im gonna go with which ever one will match up ill make it where i can use aftermarket gauges this is only like my second time doing a full interior but i just want to style it after an old mustang ive always loved the interiors on them and this ranger was my first car i got when i turned 12 so i just want everything to be perfect on her
Old 09-20-2013, 05:31 PM   #13
Commercial Member
matcox83's Avatar
Could you just get the components, cluster, glove box door, dash pad, etc and fabricate the sheet metal dash? I like the simplicity of the '65/'66 dash.
Old 09-20-2013, 07:04 PM   #14
id probably do some fiberglass work on it to fabricate it rather then metal easier to work with ill be molding my own center console bed cover and roll pan the truck is going to be used for drag and shows so im trying to go as light as possible
---------- Post added at 07:03 PM ---------- Previous post was at 07:00 PM ----------
I would love to have the steering wheel from one and the pedals
---------- Post added at 07:04 PM ---------- Previous post was at 07:03 PM ----------
I really like daddyo's dash
Old 09-20-2013, 08:10 PM   #15
Commercial Member
matcox83's Avatar
Here's the numbers for a '66. Everything's assembled with the dash pad in place and included in the height and depth numbers.
Width 53"
Height approx 11"
Depth (base of windshield to edge of pad 10"
Column tube 27" from wheel to firewall with another inch or two outside
Wheel diameter 16"
Gauge openings 4 X 1 9/16" and 1 X 3 1/2" (4 gauges and 1 speedo)
The glove box is a little cardboard deal that I didn't measure but its probably 8" or so deep.
The dash pad sticks out a couple of inches so you don't need the full 10" from the base of the windshield. The "face" of the metal dash is flush with the door opening, the cluster and glove box door stick out from there.
I'll get a pic from the side. Can't right now though.
Hope that's what you're looking for. Took longer to type than to measure!
Old 09-20-2013, 08:16 PM   #16
lol wanna do me one more favor? measure the door panels and post a pic? i wanna see something
Old 09-20-2013, 08:36 PM   #17
Commercial Member
matcox83's Avatar
40 1/2" wide at the top, 13 1/4" high at the front.
ID:	129677   Click image for larger version
Old 09-20-2013, 08:45 PM   #18
whats the measurements between the hole for the handle to the window roller? and from the edge to the handle?
Old 09-21-2013, 04:32 PM   #19
Commercial Member
matcox83's Avatar
From the edge to the window crank hole center is 5 7/8" and edge to door handle center is 14 1/8".
Old 09-21-2013, 07:53 PM   #20
Thank you ill do my measurements tomorrow to see what all ill have to do to make this work
05:39 PM
