C4 transmission fill tube - Mustang Evolution
Old 09-16-2013, 10:17 PM   #1
68 Coupe's Avatar
Region: Utah
Question for ya'all,
Had my C4 rebuilt and I put it back into the car. Put the tranny fill tube in and it seems to slop around a bit. I put a new o-ring on the tube and it still slops. Can't get more than 5 quarts of fluid in the tranny, because it spills out of the housing where the tube goes in . Is there a way to expand the tube, or a rubber bushing that would seal this thing? Anybody else had this problem?
Thanks!
68 Coupe is offline   Reply With Quote
Old 09-16-2013, 11:26 PM   #2
Aggiesrok's Avatar
Thanks!
Are sure that its seated? You should use a scrap piece of wood to tap on with a mallet to seat it and it should bolt to the back of the head. If you put on a new rubber ring, then you may need a new filler tube.
Seems strange that its not leaking immediately when you first add fluid. It could be leaking from a cooler line and dripping down by the filler tube.
Old 09-17-2013, 12:06 AM   #3
Tyoung68's Avatar
You could try to put some gasket sealer on it
Old 09-17-2013, 06:45 AM   #4
68 Coupe's Avatar
Region: Utah
Travis,
I tried some red rev but it wouldn't adhere to the aluminum housing very well. It still leaked.......
---------- Post added at 06:43 AM ---------- Previous post was at 06:40 AM ----------
Aggisrok,
It is definitely all the way in, the ridge on the tube is touching the tranny housing....and it's still loose. I think you are correct in that ill needs new tube.
Thanks
---------- Post added at 06:45 AM ---------- Previous post was at 06:43 AM ----------
Forgot to mention that it does indeed leak fluid as soon as I pour it in.
Old 09-18-2013, 06:41 PM   #5
DaddyO's Avatar
I agree aggie, make sure the tube is all the way into the casing. New o ring and tap it down good luck.
DaddyO is offline   Reply With Quote
04:20 PM
