1966 horn button problem - Mustang Evolution
Old 07-27-2008, 10:37 AM   #1
As you are so good at answering my obscure little questions, here's another one.
The horn button on our 1966 Mustang won't stay on the steering wheel. No matter what I try I can't get it to clip on and stay there.
The button is a metal die casting which just seems to be a push fit onto a plastic ring which is mounted on three bolts and springs and has the horn wires connected. There are three small nicks in the edge of the plastic ring but no matching bits inside the horn button. Not matter what I have tried (short of using blu-tack) it won't stay there and just pops off again.
Is there some art to this, or am I missing some special clip, or what?
Tony Merrygold
The Open Road
info@theopenroad.co.uk
www.theopenroad.co.uk
www.classiccarhireworld.com
theopenroad is offline   Reply With Quote
Old 08-15-2008, 03:20 PM   #2
66Sprint200's Avatar
Re: 1966 horn button problem
Is it the wood grant steering wheel? If so, than you may have the wrong ring on there (plastic ring). If you bought the wheel and hub adaptor kit, it should have included 3 rings. I believe the notches in each are different. There should be one that matches th back of the button. It should be as easy as just lining the button up, and then just pressing it on. I would recommend unplugging the battery so your neighbors don't get annoyed. HTH.
66Sprint200 is offline   Reply With Quote
Old 08-15-2008, 04:28 PM   #3
Yes it is the wood rim steering wheel, and it was on the car when I got it. I have tried just lining it up and pressing it on, and you're right the horn does go off, but it just won't stay on, hence the question.
Tony Merrygold
The Open Road
Old 08-16-2008, 06:32 PM   #4
It may 1 of a couple things. The 2 I think of are 1-that the plastic ring could be worn down, because that wheel could have been on the cars for a long time or 2-Someone might have put the adaptor for a different wheel on. Try changing the plastic ring. You should be able to buy one on ebay, or get an adaptor kit from your choice Mustang parts supplier. HTH
Old 08-17-2008, 02:05 AM   #5
Thanks for the advice, I'll try and track down a replacement ring.
Tony Merrygold
The Open Road
Old 08-18-2008, 06:33 AM   #6
you can get a lighter and a screwdriver, heat up the plastic and push a little nick outwards on it, do this in 3 places around the ring, it makes sort of a small clip when you do this, then after the plastic hardens again, it should clip on and stay.
SimplyOrange is offline   Reply With Quote
How To Hook Up A Horn mustangondubs Pre-2005 V6 Mustang 3 01-31-2008 10:22 AM
01 GT Horn Relay lowering kit 1996-2004 Mustang GT 8 01-10-2008 07:41 AM
'65 Horn issues Ken Classic Mustangs 4 04-11-2006 07:23 AM
Air Horn Fun!!! sctalbott The Bar 6 06-09-2004 11:51 AM
3am fog horn Monkey The Bar 2 08-03-2003 08:00 AM
09:18 PM
