The Rustang 2.0 - Mustang Evolution
Old 09-30-2013, 07:19 PM   #1
Tyoung68's Avatar
The Rustang 2.0
Well i was going to wait till i was done but i thought why not put it out there to get some suggestions. I replaced the passenger quarter and figures while I'm at it ill finish all the body work so i can paint her. So far iv deleted most of the trim and gas cap. Cut about a 1/4 of an inch on both sides of bumper (so i wouldn't have to mess with the mounting brackets) got some hood pins front and rear sway bars one inch lowering blocks thinking about getting rid of the back up lights and putting some leds under it for when i reverse so i can still see. Shaved the quarter panel reflectors got some new trim for the grill area. And I'm thinking about getting some new gauges haven't decided yet
ID:	130964   Click image for larger version
ID:	130966   Click image for larger version
ID:	130968   Click image for larger version
ID:	130970   Click image for larger version
ID:	130972   Click image for larger version
Old 09-30-2013, 07:31 PM   #2
Black on Boss's Avatar
Looking good bro
Old 09-30-2013, 07:59 PM   #3
LukeRailey68's Avatar
Nice!
LukeRailey68 is offline   Reply With Quote
Old 09-30-2013, 08:29 PM   #4
Iggy's Avatar
Looks good it's awsome to see these beasts come back to life love it !!!!
Iggy is offline   Reply With Quote
Old 09-30-2013, 08:40 PM   #5
ER12883's Avatar
Nice! Keep up the good work!
ER12883 is offline   Reply With Quote
Old 09-30-2013, 09:12 PM   #6
Aggiesrok's Avatar
Looking great. Auto meter gauges are awesome.
Old 09-30-2013, 09:27 PM   #7
ER12883's Avatar
I just have to throw this opinion of mine out there: I think the look of the stock 67/68 gauges are just awesome. I personally love the center piece where you can't see the "hub" where the needle connects. I don't know why but that has always appealed to me.
Old 09-30-2013, 09:53 PM   #8
Tyoung68's Avatar
Thanks guys it feels good. I ordered a guage support from cjponyparts and i think im going to start to piece together a cluster. I already have a fuel and volt gauge. What are the best gauges?
Old 09-30-2013, 11:21 PM   #9
Aggiesrok's Avatar
Obviously I like Auto Meter. But they have a huge selection of styles. I put in 2 1/16" Fuel, Oil Pressure and Engine Temperature with 5" a Speedo and Tach. They have the correct ohms fuel gauge and the speedo bolts right up. The temp and oil pressure senders bolted right also. The only challenge was hogging out the speedo and tach to 5" in the original instrument panel. The smaller gauges fit right in. I fabbed gauge holders for 5" ones out of a strip of aluminum. Wired the back lights to the oem lights circuit to get dimming from headlight switch and all new wires for senders. Also used a relay for the gauge 12v power.
Old 10-01-2013, 01:56 AM   #10
Tyoung68's Avatar
I thought about making my own template. Was it hard? And of you don't mind me asking how much did all the gauges cost you?
Old 10-01-2013, 11:38 AM   #11
Aggiesrok's Avatar
It was right around $500 for all five gauges, from JEGS. I bought them over a couple of months. I bought a new instrument panel and modded it. It wasn't hard just a little time consuming. You only have to modify the holes on the instrument panel for the 5 inch gauges, the 2 1/16 gauges fit fine. I used a dremel tool to modify the holes. Also I used a small drum sanding attachment in a drill press to clean up and smooth the openings. Some people have made these mods by cutting the Auto Meter glass off and inserting from the back of the instrument cluster. I chose to make the opening fit the whole gauge and insert them from the front, preserving the glass and not exposing the gauge or having a plastic factory lens. You have to modify the metal back plate. I fit all my gauges in the plastic instrument panel first, then marked the metal backing for cutting.
You have to cut openings for all of the gauges. I found it best to keep the metal back, it gives it needed structure as well as support for the wiper switch.
The mods for the 5 inch gauge bracket was with 1/8 aluminum bar about 1 inch wide. I just drilled a hole for the speedo cable connector and bolt holes, then bent with a vise so it would secure it. I'll take a better picture so you can see the large gauges mounted from the front better.
It's awesome being able to see everything and get accurate readings, the Auto Meter gauges each have a light bulb cover, so you can go green or amber for the lighting. I found many different colored wire at home depot to keep it all separated, as well as a bunch of blade connectors.
Old 10-01-2013, 09:03 PM   #12
Tyoung68's Avatar
Hmmm that seems like a lot of work and i might be able to sell my cluster i ordered the guage support from cjponyparts but its on back order u till next week
Old 10-01-2013, 11:47 PM   #13
Tyoung68's Avatar
Did some more bodywork today and tapped the windows and trim. Just a little more blocking then another coat of primer then its ready for paint
Old 10-01-2013, 11:51 PM   #14
Idea! I'm studying business, your amazing with car work.... We should open a body/ paint shop!
Old 10-02-2013, 12:04 AM   #15
Tyoung68's Avatar
Ha i hate body work... So lets open a speed shop
Old 10-02-2013, 12:05 AM   #16
Tyoung68's Avatar
Heres the work
Old 10-02-2013, 12:09 AM   #17
That crossed my mind also actually, also thinking of maybe a detailing business...
---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
But your freakin boss at it... That crossed my mind also actually, also thinking of maybe a detailing business...
Old 10-02-2013, 12:13 AM   #18
Tyoung68's Avatar
That crossed my mind also actually, also thinking of maybe a detailing business... ---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
i
Iv thought about all of these too so i thought of just combining all of then into a custom car shop. That will do everything from paint to superchargers
Old 10-02-2013, 12:15 AM   #19
i Iv thought about all of these too so i thought of just combining all of then into a custom car shop. That will do everything from paint to superchargers
I thought that also...... I think we might have an idea in the making.
Old 10-02-2013, 12:18 AM   #20
Tyoung68's Avatar
Ha hell yeah just need a shop and overhead
Old 10-02-2013, 12:21 AM   #21
My Uncle is a business guy, started a sheet metal fabrication business (in Morgan Hill, if you know where that's at) from scratch with a business partner. Now he has a 2 million dollar house in Saratoga. I could probably get some start up from him.. I could probably also see if he has extra warehouse space. There are also places that help start up businesses with funds and other stuff.
Old 10-02-2013, 12:24 AM   #22
Tyoung68's Avatar
Really!? Id be down if it really came down to it we could start at my house till we had enough to get a place
Old 10-02-2013, 12:27 AM   #23
The hardest part is finding clientele. I don't know too much about this area but I've seen a LOT of older folk, I don't really think they'd be interested in performance or custom cars lol.
Old 10-02-2013, 12:34 AM   #24
Tyoung68's Avatar
The hardest part is finding clientele. I don't know too much about this area but I've seen a LOT of older folk, I don't really think they'd be interested in performance cars lol.
Ha yeah well your area is pretty much a bunch of rich old people. But in walnut creek/ concord / pleasant hill area there are a million ricers and as much as i hate it that would probably be most of the clients i don't think it would be to hard to get work just post an ad on cl or just go to meets and get a fb page and some Business cards
Old 10-02-2013, 06:20 AM   #25
Muscle only, no ricers allowed. I have a business degree as well and I love the speed shop idea just no ricers come to GA and I'll partner up with y'all
Old 10-02-2013, 06:40 AM   #26
mystang50's Avatar
I'd take my stang to yall
Old 10-02-2013, 06:56 AM   #27
ER12883's Avatar
But you know back in the day some of those old folks were hot rodding their roadsters!
Old 10-02-2013, 08:54 AM   #28
Um 2 of us over here 1 over there, I think we have you out numbered. Looks like you might need to move..... You could be a second branch.
Old 10-02-2013, 08:58 AM   #29
ER12883's Avatar
Meet in the middle in CO, I'll be your first customer
Old 10-02-2013, 10:15 AM   #30
It's mostly older ladies I see at Safeway lol
Old 10-02-2013, 11:19 AM   #31
Tyoung68's Avatar
Haha as much as i would like that it just wouldnt be enough customers at the start
Old 10-02-2013, 11:26 AM   #32
Yea so many ricers nowadays it would be easy to get them as customers....
We really need to meet up some time and talk all this over.
Old 10-02-2013, 02:06 PM   #33
Tyoung68's Avatar
Hell yeah dude as soon as i paint my car we can go for a cruse and talk about it
Old 10-02-2013, 06:43 PM   #34
And that's why y'all need to come to GA lots of muscle here
Old 10-02-2013, 06:55 PM   #35
Tyoung68's Avatar
Haha well we can get to the muscle only shop after we get all the over head we need
05:04 AM
