Where can I find steering damper for 66 manual steering? - Mustang Evolution
Old 11-04-2013, 05:17 PM   #1
Daniod9's Avatar
Anyone know where to find a steering damper, piston, stabilizer?
Daniod9 is offline   Reply With Quote
Old 11-04-2013, 11:36 PM   #2
Tyoung68's Avatar
Cjponyparts npd mustangs plus
Old 11-05-2013, 06:56 AM   #3
ER12883's Avatar
Jegs usually has decent prices too
ER12883 is offline   Reply With Quote
Old 11-05-2013, 07:00 AM   #4
Daniod9's Avatar
I've actually looked on both sites. Not exactly sure what it is I should be buying, any help please?
Old 11-05-2013, 07:10 PM   #5
Commercial Member
matcox83's Avatar
Manual steering does not have any of that. In fact, neither does power steering. Those parts are usually on 4wd or off road trucks. If you can say why you think you need them, maybe we can come up with the right terminology.
Old 11-05-2013, 07:53 PM   #6
Tyoung68's Avatar
Are you talking About this ?
Old 11-05-2013, 08:16 PM   #7
Daniod9's Avatar
I think thats exactly what i'm looking for. I put new rims and tires 15's, 351w, mechanic said steering needs to be safer.
Old 11-05-2013, 08:26 PM   #8
Tyoung68's Avatar
Thats for power steering and you said you have manual. Sooo if i were you id crawl under your car with a long screw driver and start prying on things to see if you have ant bad bushings. Now just because your mechanic said you needed it doesnt mean its true
Old 11-06-2013, 05:03 AM   #9
Commercial Member
matcox83's Avatar
Mechanic could still be referring to a steering stabilizer like on a Jeep. I don't know if they make them to fit a Mustang. I agree with Travis its not needed if it's in good shape.
Old 11-06-2013, 07:35 AM   #10
Daniod9's Avatar
Thanks. That's exactly what it is. At high speeds the manual steering does not feel safe, trying to sure it up. Any other suggestions?
Old 11-06-2013, 10:01 AM   #11
Commercial Member
matcox83's Avatar
Entire front end rebuild kits with tie rod ends, ball joints and control arm bushings aren't too expensive, but labor will drive the price up. Make sure your tires are balanced first. If the front end just feels loose and you have to constantly correct, get the steering gear box checked.
Old 11-06-2013, 10:19 AM   #12
Tyoung68's Avatar
Is there a lot of play in you wheel ?
02:37 AM
