1968 Transmission Problem - Mustang Evolution
Old 11-04-2013, 09:56 PM   #1
Hey everyone have a question regarding my 68 Mustang. When shifting into reverse my pony shifts hard going into that gear and makes like a clunking sound as well. It does it when the engine is cold and hot. Any ideas what may be causing this and what possible fixes I can try? The transmission fluid is within normal limits and have not noticed any transmission leaks. The engine is a 302 V8 with a 3 speed auto transmission. Thanks for any help you all can provide.
fire6077 is offline   Reply With Quote
Old 11-04-2013, 10:01 PM   #2
JDM
JDM's Avatar
Check the motor mounts & transmission mount.
JDM is offline   Reply With Quote
Old 11-04-2013, 10:06 PM   #3
Ok will do. Thanks.
Old 11-04-2013, 11:35 PM   #4
Tyoung68's Avatar
Your transmission bands go be worn might wanna try to tighten it a little i had that problem with my car and that fixed it
Old 11-05-2013, 10:22 AM   #5
DaddyO's Avatar
Maybe u joints on driveshaft are bad
DaddyO is offline   Reply With Quote
Old 11-07-2013, 01:29 AM   #6
Thanks guys. I'll will check those things out.
Old 11-15-2013, 12:16 AM   #7
With the Transmission in Park, (do not set the Emergency Brake), Engine OFF and wheels chocked, climb under the car and turn the driveshaft back and forth; this may help narrow down the location of the noise.
As already mentioned the U-Joints could be at fault, Mounting areas need to be checked for damage or loose bolts and you may need to inspect the input shaft and yoke for damaged or worn teeth and it could be inside the differential.
suskeenwiske is offline   Reply With Quote
Old 11-15-2013, 11:16 AM   #8
rbohm's Avatar
this, the front u joint is likely bad and needs replacing kind of like NOW.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
06:29 AM
