Drivers door stuck - Mustang Evolution
Old 11-28-2013, 02:23 PM   #1
iStang65's Avatar
Region: Alaska
Drivers door stuck
So I drove my car one last time to fill her up with gas and pulled in the driveway and couldn't open the door. Had to climb out the passenger door but I just couldn't get it to open. Anyone got any advice?
iStang65 is offline   Reply With Quote
Old 11-28-2013, 02:25 PM   #2
TorchRed6's Avatar
is it locked? maybe it didnt unlock like it should have. lock,unlock,try to open it again.
TorchRed6 is offline   Reply With Quote
Old 11-28-2013, 02:28 PM   #3
iStang65's Avatar
Region: Alaska
I can't do anything with the lock. Ice tried pulling the lock knob up and push it down but it almost feels like the cable must have broke off
Old 11-28-2013, 08:15 PM   #4
TorchRed6's Avatar
that...that sucks. idk how you get that thing open without a prybar...
Old 11-29-2013, 01:10 AM   #5
Aggiesrok's Avatar
Have you pulled the door panel off? One of. The rods may have come loose. Or the spring in the latch mechanism may have broken.
Old 11-29-2013, 04:53 PM   #6
Tyoung68's Avatar
What happens when you pull the door handle?
Old 11-29-2013, 07:57 PM   #7
iStang65's Avatar
Region: Alaska
Absolutely nothing. Haha
---------- Post added at 06:57 PM ---------- Previous post was at 06:56 PM ----------
Not yet, now that we're covered in snow here in alaska I figured I have until the snow melts in May to fix it
Old 11-29-2013, 08:14 PM   #8
Tyoung68's Avatar
Originally Posted by iStang65 View Post
Absolutely nothing. Haha ---------- Post added at 06:57 PM ---------- Previous post was at 06:56 PM ---------- Not yet, now that we're covered in snow here in alaska I figured I have until the snow melts in May to fix it
Ha what about putting the key in the lock?
Old 11-29-2013, 09:46 PM   #9
iStang65's Avatar
Region: Alaska
Nothing either. It's as if it's not latching on to anything
Old 11-29-2013, 09:51 PM   #10
Tyoung68's Avatar
Well thats weird hmmm i have no idea what to tell you wish i could help more
Old 11-29-2013, 10:22 PM   #11
Commercial Member
matcox83's Avatar
The rods attach with clips. The most likely scenario is a rod has come loose. But even then you should be able to get something to function. You will need to take the panel off as previously suggested.
Old 11-29-2013, 11:41 PM   #12
Aggiesrok's Avatar
If you take off the small window rubber at the top of the door when it's open, with a flashlight you can see if the rod is connected to the handle button.
I think it's the latch mounted on the door that engages on the latch post mounted to the body where the door shuts. There is a spring inside that little box. You should be able to release it with the door panel removed.
Old 12-02-2013, 10:05 AM   #13
LukeRailey68's Avatar
Stuck lock? I would try graphite before any disassembly. It somehow works like a charm.
LukeRailey68 is offline   Reply With Quote
Old 12-04-2013, 08:59 AM   #14
Cleve Steve's Avatar
I would take the door panel off and look up in there. It will be tight doing it with the door closed but this way you can get a good look without doing damage. I had to replace the door locks on my 65. Mine wouldn't lock. It's pretty inexpensive and easy to do.
Cleve Steve is offline   Reply With Quote
02:52 PM
