Temperature Gauge Not working in 67` project ( Need Help Wit Wiring It) - Mustang Evolution
Old 12-16-2013, 07:42 PM   #1
Joshy's Avatar
I have a 1967 Mustang with a 289 and I have the gauge for the water temp and the sensor is there behind the distributor. So, I am just wondering what color the wire is that is supposed to go to the water temp gauge and where it is supposed to be assuming it is there. Any pictures or diagrams would help too. My internet search hasnt helped me much unfortunately. Thanks in advance.
www.petom.biz
Joshy is offline   Reply With Quote
Old 12-16-2013, 10:10 PM   #2
samuelsmith's Avatar
Old 12-16-2013, 11:47 PM   #3
Joshy's Avatar
Originally Posted by samuelsmith
Thank you very much. I appreciate it.
www.petom.biz
Old 12-17-2013, 09:41 AM   #4
ER12883's Avatar
Man, I miss his web show.
ER12883 is offline   Reply With Quote
Old 12-19-2013, 02:31 PM   #5
Joshy's Avatar
So, if nothing happens when the wire is grounded that means the gauge is bad? Also, the ignition will turn the car off but will not start the car. What does that mean?
www.petom.biz
Old 12-19-2013, 03:10 PM   #6
Your welcome, glad I could assist. His show is informative, sorry I did not learn any more.
Old 12-19-2013, 11:01 PM   #7
Aggiesrok's Avatar
Assuming the wire is not broken, it usually means the gauge is bad. Those old wires get brittle and break easily.
Ignition could be several things. First would be check the ignition relay on the firewall by the battery, it's fairly cheap and does go bad. Could be the wire from ignition switch to the relay or the ignition switch itself. Voltmeter will be your friend for this one.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 12-20-2013, 12:13 AM   #8
Joshy's Avatar
Okay, well ill look it over really good tomorrow. My voltmeter is crappy. Haha. I appreciate it. I will report back with my findings.
Oh, also I was kind of curious what fuses should I use. The ones that the fuse box calls for seem to be difficult to find.
www.petom.biz
Old 12-20-2013, 01:37 AM   #9
Aggiesrok's Avatar
Some of the fuses are hard to find in the size required. I used some that were close in amp when needed.
You really just need voltage on your meter. Check for 12v on the starter cable side if the relay when turning the ignition switch (you'll need a buddy).
If you get 12v and it doesn't turn over, then it's your starter or starter cable. If no bolts then you have bad relay or wire or key switch. Just keep ruling stuff out.
Old 12-20-2013, 02:13 AM   #10
Joshy's Avatar
Cool. I will keep that in mind while I'm looking it over. Thanks again!
www.petom.biz
06:20 PM
