Master cylinder bore size? - Mustang Evolution
Old 12-26-2013, 04:22 PM   #1
Tyoung68's Avatar
Im having problems with my brakes and my master cylinder. I have wilwood disk brakes on the front already and was looking at wilwood master cylinders and the have different bore size. I watched the video from summit racing about the different sizes and what they mean I just don't know which one i need. So my set up is power brakes wilwood 4 piston disk with a 8in out of a 67 with a I6 so my options are 7/8" 1" and 1.12" so which one be the best for my set up and why?
Old 12-26-2013, 09:14 PM   #2
Tyoung68's Avatar
Anyone?
Old 12-28-2013, 11:04 PM   #3
Tyoung68's Avatar
Well for anyone that needs the info heres what i found. If you have a"hard" pedal but soft brakes you have the wrong master cylinder bore size. I called wilwood and they said for my set up (67 8in rear end and wilwood 4piston big disk brakes power brakes ) depending on how much vacuum my brakes use i either need a 1" bore if my brakes use 20-24 lbs of vacuum and if the use more then i need the 1 1/8 " bore master cylinder
So now my question is how do i measure how much vacuum my booster uses?
Old 12-29-2013, 04:54 PM   #4
BA68 mustang's Avatar
Plug in a vacuum gauge into the vacuum line that goes to your booster. I think you can rent one from autozone or advanced auto
BA68 mustang is offline   Reply With Quote
Old 12-29-2013, 07:17 PM   #5
Tyoung68's Avatar
Well i work at autozone and we didnt have a vacuum gauge so ill order it online i guess
03:41 PM
