Vibration issue - Mustang Evolution
Old 01-23-2014, 07:56 PM   #1
BA68 mustang's Avatar
Vibration issue
I have a vibration in the steering wheel/column at high idle and at about 1500 rpm. Nothing is contacting the frame that would cause vibration. My motor mounts are tight, I have the correct flexplate and the harmonic balancer isn't spun. My last guess is the trans mount is bad. Has anyone had this issue in the past? Is there any way to test the harmonic balancer to see if it's bad? I don't want to throw money at parts and just hope it works, thanks in advance.
BA68 mustang is offline   Reply With Quote
Old 03-12-2014, 08:08 PM   #2
curt68's Avatar
Would think you could take harmonic balancer to machine shop and they may be able to see if it's true??? I would probably take wooden stick ( like cut off broom handle ) and hold it on engine in different areas while idling to see if it's greater in one area verses another, then dig deeper from there
curt68 is offline   Reply With Quote
Old 03-12-2014, 08:21 PM   #3
Aggiesrok's Avatar
Did you check the motor mounts for separation. They get old and the rubber separates from the steel or people use the oil pan to jack up the front of the car and tear the rubber. so they can be tight but not connected, if that makes sense. I've had that and the engine torqued, rotated up a little and the fan cut my upper radiator hose.
Old 03-13-2014, 04:31 AM   #4
I tracked it down to the incorrect flexate, someone had a 0 oz on and I needed a 28.2oz. It's silky smooth now thanks though
Issue with flywheel on an engine swap awwphooey 1996-2004 Mustang GT 10 10-15-2012 04:27 AM
EVAP issue plaguing Mustangs! fluffyGT06 General Mustang Discussion 2 12-01-2011 11:56 AM
mustang drivability issue wss003 1979-1995 Mustang GT 2 11-02-2011 08:14 PM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
gauge issue mrc 1996-2004 Mustang GT 3 09-13-2011 08:14 AM
11:56 PM
