Timing a l6 - Mustang Evolution
Old 01-24-2014, 08:46 PM   #1
Tyoung68's Avatar
Timing a l6
So i had to re gasket my engine and in the process i took my distributer out and now i cant get it to fire. Im almost positive that it is my timing anyone know how to set the distributer in? Of have a picture of your distributer at tdc with the cap off? Thanks!!
Old 01-24-2014, 09:24 PM   #2
Aggiesrok's Avatar
Set the the engine to TDC, make sure it's TDC after compression stroke. You should know roughly where No. 1 was on the cap, mark no. 1 on dist base with cap off. . Drop in distributor and line up rotor with mark. Now move the engine to your timing setting, 14 degrees btdc ( or whatever the I6 timing is). Now move the distributor til the rotor lines up with the mark you made earlier. If you can't turn the distributor enough to line up with the mark and have a little room for adjustment, then pull out the dist enough to disengage the gear and rotate it over a tooth or two in the needed direction, then adjust as before. This should get you close enough to start and time with a light. This is how I did my 289 and it worked fine. Before, I had the same problem, off enough to not start.
Old 01-31-2014, 12:44 AM   #3
Tyoung68's Avatar
Well i did everything you said and right before i tired to start it i noticed a coolant leak and tried to tighten the thermostat housing where it was leaking and it cracked
Old 01-31-2014, 07:51 AM   #4
Aggiesrok's Avatar
Bummer! Hopefully you're close. It probably already had a small crack, better to find out now. But
it would have been nice to at least get it started for a minute.
Old 01-31-2014, 04:33 PM   #5
Tyoung68's Avatar
I dont think there was a crack... Haha it was leaking and i just over tightened it
Old 01-31-2014, 04:44 PM   #6
Tyoung68's Avatar
Old 02-07-2014, 01:23 PM   #7
Tyoung68's Avatar
Well not only did i crack the housing i broke a bolt too and now i broke the ez out in the bolt now....
Old 02-08-2014, 11:46 PM   #8
ER12883's Avatar
Oh man, I just had flashbacks to a cylinder head bolt I snapped off in a ranger engine. I feel your pain brother, good luck!
ER12883 is offline   Reply With Quote
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
94 Mustang timing question workmail21 1979-1995 Mustang GT 5 09-20-2012 02:23 PM
Timing Chefnick 1979-1995 Mustang GT 2 11-20-2011 07:55 PM
advancing timing 5.slow 1979-1995 Mustang GT 6 08-10-2011 10:40 AM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
04:45 AM
