1966 coupe speedo problem - Mustang Evolution
Old 01-27-2014, 11:58 AM   #1
Region: Oregon
My speedometer is fallen below zero and no its constantly 10 mph slow. So is their any way to reset it manually?
connor66 is offline   Reply With Quote
Old 01-28-2014, 04:36 AM   #2
go501green's Avatar
You can try lubing the cable but it may be worn and need replacing. It's a cheap fix if you do it yourself.
go501green is offline   Reply With Quote
Old 01-30-2014, 03:15 AM   #3
Tyoung68's Avatar
Is it stock?
Old 01-30-2014, 10:23 AM   #4
Commercial Member
matcox83's Avatar
I had debris in my odometer from all the body work so it got stuck which made the speedo bounce. You might be able to clean up the speedo mechanism and make it so Rohr again.
Old 01-30-2014, 10:25 AM   #5
Commercial Member
matcox83's Avatar
"So Rohr" means "work" without spell check! New speedo for '66 was $85, btw
1966 Mustang Coupe V-8 new suspension Seattle66 Classic Mustangs 1 01-17-2012 09:20 AM
Does any1 know how much horsepower can the internals of 1996 3.8l take?? M_PZoe Pre-2005 V6 Mustang 16 12-19-2011 09:37 AM
-->MACH speaker problem... HELP!!!! DaMan Mustang Audio & Video 7 11-27-2011 04:55 AM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1966 coupe roof gc19662007 Classic Mustangs 8 08-21-2011 01:22 AM
12:09 AM
