Pushrod Length 67 289? - Mustang Evolution
Old 02-05-2014, 05:47 PM   #1
Aggiesrok's Avatar
I had a rattling rocker arm. Turned out to be No. 1, tightened it and it began pulling out the crappy pressed in stud. So I pulled the heads and had screw studs installed (solved one problem). So the new studs are now 3/8" and my old rocker arms will not work. I got the car last year and don't know the cam brand or cam specs (it's a mild cam). I ordered Comp Cam 3/8" rocker arms with roller tips and 1.6 ratio, so standard for the most part. The block is 289 and the heads are 302 with non-rail rocker arms.
So the magic question is: Can I use the original push rods or do the roller tips change the required pushrod length?
Old 02-10-2014, 08:43 PM   #2
Aggiesrok's Avatar
Got it figured out and it's up and running again. Talked to the comp cams tech guy and it's designed for a stock rocker arm swap. So now it's got screw in studs and roller tip rocker arms. It seems to run better, the roller tips are supposed to add some HP. It's more efficient and it think the valves operate more precisely.
Old 02-10-2014, 08:53 PM   #3
Tyoung68's Avatar
So you were able to use your stock ones?
Old 02-10-2014, 10:44 PM   #4
Aggiesrok's Avatar
Yeah no change needed
Old 02-11-2014, 02:59 AM   #5
ER12883's Avatar
Nice
ER12883 is offline   Reply With Quote
Belt length for vortech gt with 3.33 pulley Dustin541 1996-2004 Mustang GT 6 01-17-2014 09:36 AM
Tuned length shorties. Torrbo916 1996-2004 Mustang GT 8 12-20-2011 11:00 AM
Oil and gas for 66 with 289 Seattle66 Classic Mustangs 5 11-17-2011 07:03 PM
Difference between 289 and 302 my65 Classic Mustangs 12 10-16-2011 08:47 PM
Will a 6 cylinder C4 work with a 289 Tuch65 Classic Mustangs 2 08-11-2011 05:13 AM
04:51 AM
