Tach Issues - Mustang Evolution
Old 02-13-2014, 10:57 PM   #1
renouji's Avatar
Region: Utah
Send a message via Yahoo to renouji Send a message via Skype™ to renouji
Tach Issues
My tach isnt working at all and I cant figur out why. my coil wire definitely goes to the coil but I cant track down my battery wire....It worked the first day I bought the car but never since. any ideas or suggestions?
renouji is offline   Reply With Quote
Old 02-13-2014, 11:36 PM   #2
Aggiesrok's Avatar
Is the tach wire broken? You'll need to make sure you get 12v and a good ground. The tach wire is just a trigger.
Old 02-14-2014, 12:55 AM   #3
renouji's Avatar
Region: Utah
which one is the tach wire? the battery or the coil? and how do i test it?
Old 02-14-2014, 08:02 AM   #4
Aggiesrok's Avatar
The bestiary to test is to pull the gauge or cluster to access he back of the tach. You should have a 12v wire (active with ignition on), a ground wire and a tach wire going to the negative side of the coil. If you have electronic ignition, the tach wire may go to the ignition module and not the coil. you'll need a multi-meter to check voltage with key in "on" position. You should look at a wiring diagram to track down the tach wire. Or check the color code of the wire coming out of the tach and follow it to the coil or module. You could check this wire for continuity with the multi meter. It may be cracked and shorting or bad connections.
1996 Electrical Issues - Various ??? TexomaEV Pre-2005 V6 Mustang 2 11-10-2012 05:41 PM
Bama 93 series tune issues after H-Pipe install 2013_stang_gt 2011-2014 Mustang GT 7 09-26-2012 04:31 PM
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
01:45 AM
