Engine cutting out - Mustang Evolution
Old 02-18-2014, 02:04 AM   #1
Tyoung68's Avatar
Engine cutting out
So as many of you guys know i have a 68 with a l6. If i try to turn hard or floor it with the wheels cranked ( like to try to do a dough nut) it just dies no sputter or anything just shuts off. Any ideas?
Old 02-18-2014, 10:06 AM   #2
LukeRailey68's Avatar
Hmmm is that from running rich?
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
Happens to me too
LukeRailey68 is offline   Reply With Quote
Old 02-18-2014, 12:19 PM   #3
Aggiesrok's Avatar
Does it happen if you turn hard right or left? Or just in one direction. Since you've got an I6, is your carb mounted sideways as far as the fuel bowl goes? It seems like you may have a fuel bowl float problem and lateral force causes a flood or super lean problem. Only thing I can think of at the moment.
Old 02-18-2014, 01:10 PM   #4
Tyoung68's Avatar
It happens both ways
Old 02-18-2014, 02:00 PM   #5
ER12883's Avatar
Does the same happen if you turn it full lock but at a crawl? That would rule out a fuel bowl problem. Power steering or manual?
ER12883 is offline   Reply With Quote
Old 02-18-2014, 02:16 PM   #6
Tyoung68's Avatar
Manual and only if i floor it
Old 02-18-2014, 03:51 PM   #7
BA68 mustang's Avatar
Could it be a loose electrical connection somewhere? I'm just throwing out ideas
BA68 mustang is offline   Reply With Quote
Old 02-18-2014, 03:56 PM   #8
Tyoung68's Avatar
Iv thought so but if it was it would seem like every time id go over a bump or into a drive way it would cut out but it doesn't i guess this just another reason to get a v8 haha
Old 02-18-2014, 04:00 PM   #9
Does this only occur while you're turning?
If you mash the pedal in a straight line does the engine die as well?
Old 02-18-2014, 04:01 PM   #10
Tyoung68's Avatar
Only while turning its fine in a straight line
Old 02-18-2014, 04:03 PM   #11
Hahahaha I like the way you think. When you step up to a v8 put a OD trans and steeper gears in it. I have a 68 coupe with a warmed up 289 and a c4 with 2.79 gears and well let's say that it barks harder than it bites 😢
Old 02-18-2014, 04:05 PM   #12
Tyoung68's Avatar
Ha yeah im thinking a 351 or f it and get a big block haha it depends on when i can get it and for how much. Im taking machining classes at school and i can do all the work
Old 02-18-2014, 04:13 PM   #13
Lucky you, I wish my school had a machine shop. I would go with a 302 with the kasse p38 heads if I had the money
Old 02-18-2014, 04:21 PM   #14
Id look into building a FE engine for your car... 390 or 428. They're getting hard to find though.
So what have you done to the car since this started to happen? I know that you recently had the engine out didn't you?
If it justs dies cold, it sounds like its probably electrical. Go through and double check EVERYTHING! After that, start jiggling wires while the engine is running and see if you can make the engine die.
I'm guessing that after it dies while turning that it starts right back up like nothing happened,
Remember: 46 year old cars have 46 year old wiring...
Old 02-18-2014, 04:32 PM   #15
Tyoung68's Avatar
Engine cutting out
The engine was just out but it did it before too and the wiring is actually new i think its just not getting enough fuel or too little. And i think thats what im going to do. I mean everyone has a 302 not many can say the have 390ci or higher
Old 02-18-2014, 04:55 PM   #16
FE's are very light engines for being cast iron. As a matter of fact, the modular engines are cast the same as the old FE's.
I would expect there to be some sputtering if this was fuel related, but check your float level in the carburetor and you might also make sure that the accelerator pump on the carburetor is functioning properly.
Old 02-18-2014, 07:37 PM   #17
Aggiesrok's Avatar
Go for a 351, not too heavy and parts are easy to get.
Your problem must be fuel related, since it's based on inertia. It must be the carb, because any other fuel interruption would not be instant, because of the fuel in the bowl. Unless your coil or coil wire are loose. But then it seems unlikely that it would restart each time right away.
Old 02-18-2014, 09:31 PM   #18
Tyoung68's Avatar
Ill probably end up getting a 351 is there a best year to get? Like are the blocks better from any years ?
Old 02-18-2014, 10:10 PM   #19
Cleveland
Old 02-18-2014, 10:18 PM   #20
Tyoung68's Avatar
Originally Posted by straybullitt View Post
Cleveland
Why Cleveland?
Old 02-18-2014, 10:33 PM   #21
The Cleveland or 335 series engines were considered the factory hot rods while they were in production. It's this series that the Boss 302 and Boss 351 were based on. They basically had excellent flowing heads for their time.
The Windsors were considered the workhorses.
Nowadays, the aftermarket heads for the Windsor are better than the Cleveland.
But if you wanted to build a true Boss 302 or 351... gotta have a Cleveland.
Old 02-18-2014, 10:40 PM   #22
Tyoung68's Avatar
Cleveland
Why Cleveland?
Old 02-18-2014, 10:42 PM   #23
Tyoung68's Avatar
Hmmmmm well which one has more power stock and which can handle more power
Old 02-18-2014, 10:49 PM   #24
The Windsor.
It has better aftermarket support. The Cleveland has been out of production since the early eighties.
Just trying to throw out some different ideas. ..
Old 02-18-2014, 10:51 PM   #25
Tyoung68's Avatar
---------- Post added at 09:51 PM ---------- Previous post was at 09:50 PM ----------
Im really getting tired of this new app -.-
Old 02-18-2014, 10:53 PM   #26
Haha.
I've just been using the regular website.
Old 02-18-2014, 10:55 PM   #27
Tyoung68's Avatar
But theres a 5.0 block for 75 on cl sooooo that might have to do for a little
Old 02-18-2014, 11:08 PM   #28
That's why a Windsor is the most practical choice. They're dime-a-dozen. You'd pay good money just for a rebuildable FE or Cleveland core, although, I have seen them at Pick and Pull from time to time. In trucks.
Old 02-18-2014, 11:10 PM   #29
Big block!!
Old 02-18-2014, 11:57 PM   #30
Tyoung68's Avatar
Why cant everything just be free
Old 02-19-2014, 07:34 AM   #31
Aggiesrok's Avatar
Heads are everything. Find the block size you want and throw away the heads. Then get some great flowing heads and build it all from the ground up, matching all the components to work best together: cam, heads, carb, intake, valve train, etc.
Or you could just order a coyote crate engine. It's a big $ hit at once, but you're done.
Old 02-19-2014, 11:30 AM   #32
ER12883's Avatar
If you're cool saying adios to your shock towers - but at that point a suspension upgrade is pretty much mandatory.
Old 02-19-2014, 01:57 PM   #33
Aggiesrok's Avatar
Awesome is never cheap or easy.
http://rcmotorsportsinc.com/rc-107-a...rsion-package/
Old 02-19-2014, 03:02 PM   #34
Tyoung68's Avatar
Ha oh believe me iv looked at a new coyote but being a broke college student working at autozone doesn't add up to that kind of money haha
Old 02-19-2014, 03:44 PM   #35
Aggiesrok's Avatar
I hear ya!
I'd find a 351 block and start socking away heads, intake, etc. you've got a drivable ride now, so you can squirrel away parts as you can.
Gutting cats BadAssStang07 2005-2010 Mustang GT 8 12-07-2013 09:24 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Service Engine Soon Light???? wilson_j307 Pre-2005 V6 Mustang 2 03-03-2012 12:41 PM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
11:56 AM
