Horn keeps screwing up - Mustang Evolution
Old 02-23-2014, 07:47 PM   #1
Aggiesrok's Avatar
67, 289, manual steering, got the car in 2012. Original steering wheel was already replaced and not working. I replaced the steering wheel with a Lecarra last year and replaced the signal plate/wiring harness and both horns. Everything was great, then after about 7 or 8 months. The the horn started to activate as you turned the steering wheel. I took it apart and realized that the copper plate on the back the steering wheel was scored off center. I called Lecarra and without asking any questions, they sent me a new copper back plate. I added a bearing to the steering wheel shaft and keep it centered. Then installed the new plate with some dilithium grease and a new signal plate/wiring harness again. Now it's activating when turning the wheel again. Took it apart and it's destroyed one of the copper posts on the signal plate that activates the horn and there are copper filing inside everywhere. I'll call Lecarra tomorrow again, but anyone have these problems? Is there a better hub setup?
Old 02-23-2014, 09:39 PM   #2
Tyoung68's Avatar
I had the same problem withy grand my problem was the actually steering wheel was flexing causing the plates to contact each other
Old 02-23-2014, 10:37 PM   #3
Aggiesrok's Avatar
What did you do, new column?
Old 02-23-2014, 10:42 PM   #4
Tyoung68's Avatar
Disconnected it... Haha its on my todo list i was going to try to find some longer bolts so there is more of gap so if the wheel flexes a little it wont make contact
Old 02-23-2014, 10:48 PM   #5
Aggiesrok's Avatar
I feel like I'm missing something inside the column.
Old 02-23-2014, 10:53 PM   #6
Tyoung68's Avatar
What do you mean?
Old 02-23-2014, 11:13 PM   #7
Aggiesrok's Avatar
Like it's missing a centering bracket or another bearing. It's just weird that it ate that horn pin off the wiring plate.
Old 02-24-2014, 11:34 AM   #8
Aggiesrok's Avatar
I think you're on to something. It's so hard to turn the wheel when not moving or moving less than 10 mph. I believe that when you are muscling the steering to turn it, it's moving the steering shaft out of center and trashing the horn contact plate.
So now first question, is manual steering supposed to be that hard or is the steering box necessary?
If the steering difficulty is normal then, can I beef up the steering shaft or do I need to buy a new steering column?
Old 02-24-2014, 12:32 PM   #9
Tyoung68's Avatar
I have a new box and its still difficult to turn and as far as new steering shaft i have no idea on that one
Old 02-25-2014, 07:39 AM   #10
Aggiesrok's Avatar
I'm going to check the oil level in the steering box. It shouldn't be so hard to turn that it moves the shaft off center an it shouldn't flex the column that much. I think I've got several issues. I'd replace the column, but I don want a modified GM column.
Screwing around with the Stang!! Fudge Mustang Audio & Video 12 08-29-2013 10:39 AM
Dixie horn for my stang shsfresh87 General Mustang Discussion 13 01-07-2012 10:29 PM
Where is my horn located? Ruthless General Mustang Discussion 2 10-05-2011 08:33 AM
Horn or Light flash on locking car, here is how to disable SpectorV General Mustang Discussion 0 07-26-2011 10:30 AM
HORN PROBLEM GoldenPonyBoy 2005-2010 V6 Mustang 2 07-22-2011 11:06 AM
08:53 AM
