Blinker Problem - Mustang Evolution
Old 03-12-2014, 02:26 PM   #1
Blinker Problem
Hey guys! I just have one small problem and I'm not sure how to fix, my left blinker works perfectly fine when I finish my turn it turns off but my right blinker doesn't turn off any ideas on how to fix this? It would be much appreciated!
AsherDasher is offline   Reply With Quote
Old 03-12-2014, 03:02 PM   #2
go501green's Avatar
http://averagejoerestoration.com/how...signal-switch/
go501green is offline   Reply With Quote
Old 03-12-2014, 03:07 PM   #3
FullyAutomatic's Avatar
Region: Mexico
did you check the blinker fluid?
FullyAutomatic is offline   Reply With Quote
Old 03-13-2014, 02:18 PM   #4
Commercial Member
matcox83's Avatar
There are tabs on the switch. When the steering wheel turns back it contacts the tabs and "cancels" the blinkers. Most likely broken.
Old 03-13-2014, 03:54 PM   #5
Aggiesrok's Avatar
If its what mat cox said, then it's replacing the switch and wiring harness, it's an easy fix. But if the tabs are not broken then your steering wheel could be off center and the switch is.not being disengaged on one side.
Old 03-13-2014, 05:10 PM   #6
BA68 mustang's Avatar
I replaced the switch in my 68 and the one that came (Scott Drake) was really cheesy and it still doesn't cancel. I made sure that the tabs are both in and the clip I ordered with it to replace the one at the bottom doesn't click in.
---------- Post added at 06:10 PM ---------- Previous post was at 06:09 PM ----------
I would take the wheel off and turn the little plastic ring by hand and see if it cancels left and right
BA68 mustang is offline   Reply With Quote
13 Shelby gt500 problem , HELP!!! 13gt500 Shelby Mustang 7 02-28-2014 11:19 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 2 01-23-2012 10:28 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
10:53 AM
