New Steering Box, which ratio? - Mustang Evolution
Old 03-31-2014, 05:01 PM   #1
austinknoll's Avatar
I need to order a new steering box for my 65 mustang. its manual steering and im keeping it manual so I have the choice between a 16:1 and a 20:1 ratio. Im not sure which is better for a non power steering car. I understand the 20:1 will be easier to turn but will take more revolutions of the steering wheel to turn the wheels but is it really that big of a difference in easiness between the 16:1 and 20:1? Does anybody know the stock ratio of manual steering? Keep in mind that I am also running on new edge 17x8 bullitts so its already a little hard to turn with the wide tire.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 03-31-2014, 06:14 PM   #2
BA68 mustang's Avatar
What size tire/how sticky are they?
BA68 mustang is offline   Reply With Quote
Old 03-31-2014, 06:15 PM   #3
Tire is a 245. They're not sticky, they're just plain old road tires.
65 Mustang coupe
Old 03-31-2014, 06:32 PM   #4
Do you drive the car hard? If not I'd stick with the 20:1
Old 03-31-2014, 07:10 PM   #5
Tyoung68's Avatar
I got the 16-1 just make sure you get the right size shaft i think it was 1 1/8 or 1 1/4. I got the wrong size and had to get a new pitman arm and modify it to fit my steering linkage. But anyways iv had no problem with my box im glad i went with the 16-1
Old 04-01-2014, 11:23 AM   #6
alrefire's Avatar
16:1 would be a lot more responsive.
Also a good workout :p
Haha
If it's just a cruiser car, I'd stick with 20:1.
Are you getting one with a variable ratio or non-variable?
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 10:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
New Programmable Ratio ProCharger DWC_SmOziLLa 2011-2014 Mustang GT 12 10-27-2012 09:30 AM
1973 Mustang Power steering box leak? What needs to be done? kang29 Classic Mustangs 3 12-14-2011 09:38 AM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
06:38 AM
