Electric Choke - Mustang Evolution
Old 04-02-2014, 08:35 PM   #1
ER12883's Avatar
Electric Choke
So my choke arrived today. My carb currently has no choke on it, making it a pain to start in cool weather. I have a Carter carb, and there doesn't seem to be any readily available chokes for them, but I came across detailed instructions in how to use an Edelbrock choke kit on a Carter carb. Since EB bought the carter carb design, many of the older EB parts are direct fit for Carter.
I doubt too many of you have this specific issue, but I'll keep you posted on how it goes as I find time to work on it.
Name:	ImageUploadedByMustang Evolution1396492456.905566.jpg
ER12883 is offline   Reply With Quote
Old 04-05-2014, 11:09 PM   #2
ER12883's Avatar
I was able to get it installed - I was expecting to need to modify the linkage, but it looks like my Carter is identical to the EB this choke is made for. So it went on in about 15 minutes, and everything seems to be actuating as it should. I Still need to find the best place to hook up the 12v and test it out.
Here is my carb as it was:
Name:	ImageUploadedByMustang Evolution1396760647.388555.jpg
With the vacuum plug removed:
Name:	ImageUploadedByMustang Evolution1396760683.572773.jpg
With the base and linkage attached:
Name:	ImageUploadedByMustang Evolution1396760737.216802.jpg
All put together. Didn't think it would be as easy as it was
Name:	ImageUploadedByMustang Evolution1396760792.743279.jpg
Old 04-06-2014, 12:14 AM   #3
Tyoung68's Avatar
Didnt even have to take it off?
Old 04-06-2014, 01:05 AM   #4
ER12883's Avatar
No, since I didn't have to remove any old components, and everything was easily accessible. No complaints here!
Old 04-06-2014, 05:44 AM   #5
Mlarv5's Avatar
Looks good. The last picture looks like you found the 12V if so what did you tap for it. If not you want a switched line to make sure it is off when the key is off.
Thanks
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 04-06-2014, 09:56 AM   #6
ER12883's Avatar
That was just to test and adjust. I started her up and manually went directly to the battery just to make sure it worked and adjust it.
But I think I'm going to go to the alternator. EB specifically says not to go to the coil - after some research it's because having a lot of load on there can screw with the ignition system. I'm sure the choke wouldn't be a problem, but best practices and all.
I like how they gave me like a foot of black wire for the n
Old 04-06-2014, 09:58 AM   #7
ER12883's Avatar
Oops...
negative line when it only needs to go like 2 inches. I'll have to do some cleanup when I figure out where to go.
Old 04-07-2014, 06:40 PM   #8
ER12883's Avatar
Got it wired up to the back of the alternator, and works fine. I think the fast idle needs to be adjusted because I have to give it a fair amount of gas for it to drop down to a peer rpm. I'll look more into that, but for now, mission accomplished with the choke!
Old 04-13-2014, 08:37 AM   #9
alrefire's Avatar
Awesome job!!
Old 04-13-2014, 09:30 PM   #10
ER12883's Avatar
Minor update - it seems like the vacuum gasket fell out while I was installing it (you can see it sitting in the intake on the 4th picture). This was causing issues the first few seconds after startup. Got it reinstalled, and I'll test it later this week. Today it was snowing sideways, but we should be back close to 60 by mid week (that's Colorado).
I have a Holley 4bbl double pumper with electric choke that stays way too wide open.. 85stangrevo 1979-1995 Mustang GT 11 02-21-2014 07:45 PM
Does it matter what type of "Choke" the carburetor is when i buy it for my car? imported_Gary Classic Mustangs 2 12-19-2011 02:09 PM
Acts like the choke is sticking bizwaks 1979-1995 Mustang GT 0 03-20-2011 02:38 PM
Choke Seph The Bar 8 06-18-2008 11:57 AM
Is Wayne Brady going to have to choke a *****? JROC The Bar 4 07-16-2007 04:25 PM
09:52 PM
