Vacuum Advance - Mustang Evolution
Old 04-14-2014, 05:43 PM   #1
ER12883's Avatar
Vacuum Advance
Hi guys, so I had some time to look into my vacuum situation, and test out my brake booster.
While digging in there, I noticed my vacuum advance was capped off, and not connected to the carb. Can you confirm that this:
Name:	ImageUploadedByMustang Evolution1397518795.248933.jpg
should be connected to the carb? It's a pertronix with a flame thrower coil.
By the way, the brake booster tested great, but was hooked up with fuel line that was too small for the fitting, this is what I was dealing with:
Name:	ImageUploadedByMustang Evolution1397518885.992215.jpg
No wonder the brakes are hard as a rock, the hose was leaking like a sieve!
Thanks!
Evan
ER12883 is offline   Reply With Quote
Old 04-14-2014, 07:03 PM   #2
ER12883's Avatar
Yeaaaaah, I'm thinking I don't have any advance...well that's gonna effect how it runs!
Old 04-14-2014, 08:05 PM   #3
Aggiesrok's Avatar
Yeah no advance for sure. You should probably replace all vac lines.
What's your vacuum reading?
Old 04-14-2014, 08:12 PM   #4
ER12883's Avatar
Didn't get a measurement on it, but there's another fuel line that was falling apart, so I had leaks everywhere. Not sure how it was running decently. All new lines are in the very near future!
Old 04-15-2014, 08:18 AM   #5
Aggiesrok's Avatar
You should check all the vac plugs or caps on the intake and carb. I had some of those that looked ok, but were dry rotted and crumbled in my hand. If you have auto, check that one on the intake.
Old 04-15-2014, 11:16 AM   #6
ER12883's Avatar
Good call on the trans. I grabbed a bunch of my fittings (PCV, booster valve, etc) and I'm going to run to the parts store and get a bunch of plugs and lengths of line and redo everything while I'm at it.
I also noticed the PCV wasn't hooked up, too. Somehow with all this, I had enough vac to still draw fuel...Sometimes I really wonder about who had this car in the past. Who seriously thought fuel line poorly pushed onto the wrong size barb was gonna cut it?
Old 04-15-2014, 03:59 PM   #7
Aggiesrok's Avatar
Good deal
Used car dealers put sawdust in tranny's for temporary smooth shifting years ago. You never know what morons will do to a car.
Since your fuel lines were so bad, you might check the fuel hose where it connects to the fuel sending unit.
Old 04-15-2014, 06:57 PM   #8
ER12883's Avatar
Originally Posted by Aggiesrok View Post
Good deal
Those weren't fuel lines...that was fuel line used as vacuum hose.
Okay so I replaced the PCV, the booster check valve and all hoses. This includes getting the advance line connected to the carb.
Although I didn't have a chance to drive it, I can see the advance is working as it should. Still not sure about the brakes, they feel very firm still, but the proof will be in the pudding when I have time to drive her. I'll keep you posted.
Timing advance on race fuel. Blown347 1979-1995 Mustang GT 14 10-30-2012 12:03 AM
Timing Advance Recommendations? Ohdang1990 1979-1995 Mustang GT 5 09-30-2012 10:29 AM
Timing Advance? Nashgizam 1979-1995 Mustang GT 22 01-29-2012 01:48 PM
Timing advance jwhayne0001 1979-1995 Mustang GT 25 11-09-2011 05:55 PM
Advance Trac Ravnus 2011-2014 Mustang GT 12 04-07-2011 05:28 PM
03:58 PM
