Replacing Intake Gaskets on 67' 289 - Mustang Evolution
Old 04-27-2014, 01:19 PM   #1
Joshy's Avatar
Okay, I am now replacing the intake gaskets. I was planning on using the FelPro kit and it comes with the cork gaskets. I am planning on putting two dots of gasket sealant on each end of the gasket. However, they have small tabs on each and and appear to make it bend upwards a bit. What should I do? And are they supposed to be like this? Thanks. I have intake off and cleaned up and am not at the point where I need to put the gaskets on.
www.petom.biz
Joshy is offline   Reply With Quote
Old 04-27-2014, 01:49 PM   #2
Tyoung68's Avatar
Post some pictures
Old 04-27-2014, 02:28 PM   #3
I usually put some sealant both underneath and on top of the little tabs and then squash it down on top of the intake gaskets. You just want to be sure to seal up those four "corners" real good.
Old 04-27-2014, 04:05 PM   #4
Joshy's Avatar
That's pretty much what I did. I put sealant on all four corners where those meet.
www.petom.biz
Old 04-27-2014, 04:06 PM   #5
Joshy's Avatar
I am now torquing them down with factory spec. Wish me luck everyone. I am very nervous it might leak on me again. I do not want to do this again anytime soon. Haha. I appreciate the responses!
www.petom.biz
Old 04-27-2014, 07:16 PM   #6
Joshy's Avatar
Here is what I was dealing with. I will fill it up with water and try to run it soon to figure out if my 8 hour job has worked lol
www.petom.biz
Old 04-27-2014, 07:17 PM   #7
Joshy's Avatar
Sorry, here is the gasket that was in question.
www.petom.biz
Old 04-27-2014, 11:55 PM   #8
Awesome Josh!
It looks like it was the drivers side that was leaking. Hopefully, this will solve part of the problem that you were having. So I guess the carburetor and the ignition system are next huh?
Old 04-28-2014, 07:23 AM   #9
Joshy's Avatar
Yep. Next I will make sure the carb is hooked up correctly and then probably ignition. Maybe I should just make one thread for all of it?
www.petom.biz
Old 04-28-2014, 08:17 AM   #10
Mlarv5's Avatar
I like the separate threads because as you fix problems it is easier to follow and see what is what.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 04-28-2014, 01:46 PM   #11
Joshy's Avatar
I'll just stick to single ones then. I will update you guys when I get it filled up and try to run it. Having ignition issues I think also. But I'm hopeful the massive intake leak was was a lot of my problem lol
www.petom.biz
Old 04-28-2014, 05:23 PM   #12
BA68 mustang's Avatar
Don't forget to check the oil for water too, when I first put mine on it leaked into the oil galley as well as all over the fresh paint on my motor
BA68 mustang is offline   Reply With Quote
Old 04-28-2014, 07:30 PM   #13
Joshy's Avatar
I will do that
www.petom.biz
Old 04-28-2014, 08:03 PM   #14
Joshy's Avatar
This might be a stupid question, is the best way to check for water to just drain the oil? I probably need to anyway to put some with zinc in it
www.petom.biz
Old 05-03-2014, 01:00 PM   #15
You can just pull the dipstick and look for what appears to be milk on the end of it, there will mostly likely be a dab on the end from condensation/ any coolant left in the galley
Old 05-03-2014, 01:02 PM   #16
As far as zinc goes, I went to the local napa and got a bottle of ZDDP (zinc) additive, it was only $6
Old 05-03-2014, 03:28 PM   #17
Joshy's Avatar
I don't know that I trust myself to add it on my own. Haha. But I will definitely look into that. Thank you for the advice.
www.petom.biz
Replacing head gaskets? Mustang_Madness 1996-2004 Mustang GT 2 01-25-2013 11:14 AM
Pictures of my intake and gaskets. Mustang_Madness 1996-2004 Mustang GT 26 03-22-2012 09:21 PM
99 + intake gaskets that are not plastic? ? victory181 1996-2004 Mustang GT 1 12-14-2011 04:11 AM
Intake gaskets 88Merc 1979-1995 Mustang GT 1 04-03-2011 12:11 AM
Lower intake gaskets... 98GreenStallion Pre-2005 V6 Mustang 4 01-27-2004 09:09 PM
09:56 AM
