Any suggestions for the right radiator to cool this off? I've changed everything but the radiator so far. Want something I won't ever have to worry about.
I've heard that it is possible to have too large of a rad, and the pump isn't able to move the water through the rad fast enough to create turbulence. So the water that's cool stays to the outside and the warm water doesn't touch the rad a lot so it doesn't dissipate it's heat. Like a large slow river - near the banks the water is pretty much still. In a small fast river the banks are turbulent.
Maybe a high flow water pump? Or a smaller pulley on the water pump maybe so it spins faster?
I'm using a Northern aluminum radiator with a Kooler Cooler water pump, 5 blade mechanical fan and Water Wetter additive in a 50/50 water antifreeze mix with no problems. Good luck
If its overheating after a rebuild, check the head gaskets, the big water passage openings in the gasket should go to the back of the engine. I have seen those gaskets installed backwards before and he never could get it to stop overheating until he corrected his little issue there.
You can put in an additive that makes it run cooler. Just go down to advanced auto and they will have it. I put it in mine and it has worked extremely great. It's the cheapest, quickest and easiest fix.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
