Hey guys,
I have a 68 coupe with a 289 and a c4. I need a new trans and torque converter and it's lookin like its goanna cost about $1300. I was wondering if anyone has put a t5 in an auto and roughly how much it costed and what driveline parts if any I could reuse (drive shaft, crossmember etc...)
Thanks in advance
As far as parts you'd need new brake and clutch pedal either a kit or bell housing flywheel clutch pressure plate clutch fork TOB transmission cross member driveshaft shifter some sort of shift bezel also depends on if you get a hydraulic clutch
I did a little more research and I simply can't afford it. If I would have put a t5 in it from the start I would have spent the same amount of money in the long run with all the bs with my trans but oh well that's how it goes hahahaha.
I rebuilt mine it wasn't to bad i got my kit from macko transmission i got the over haul kit and it had everything i needed. Also i used Vaseline to lube all the o rings my grandpa who use to rebuild transmissions told me to use it because if you use anything else it'll contaminate the oil and plug the valve body
I never would have thought of that. It's funny lithe bing to the old tips and tricks. My uncle has building race engines since the 70's and I worked with him last summer, I couldn't believe the amount of little tricks he showed me.... Now if I can just rennet them all
---------- Post added at 11:54 AM ---------- Previous post was at 11:53 AM ----------
I never would have thought of that. It's funny lithe bing to the old tips and tricks. My uncle has building race engines since the 70's and I worked with him last summer, I couldn't believe the amount of little tricks he showed me.... Now if I can just remember them all
That's the thing so much easier when someone else has already done it and can make your life much easier. Or at least fresh eyes to see another way to so things
I can't tell you the amount of times that I've struggled putting a part in or figuring out a wiring issue or whatever and my old man walks over and gets it done in 5 minutes
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
