casting numbers for a 1965 289 - Mustang Evolution
Old 07-12-2014, 11:50 PM   #1
spankymcgloon's Avatar
Evening all, bought a 1965 Mustang and was told this was the original 289 that had been rebuilt, however starting to question that. The casting number above the starter reads DZOE-6015-AB and the date code on the block below the distributor reads 3D17Y. These don't seem to ad up, the wife thinks its a 302 I believe it is a 289 from my research but not original to the 1965 Mustang that we bought.
Whatever info you can provide would be grateful. Thanks in advance.
spankymcgloon is offline   Reply With Quote
Old 07-13-2014, 08:13 AM   #2
BA68 mustang's Avatar
Hmmm.... I'm assuming it's a 70's block because it starts with a "d" but the next character should be a number indicating the exact year. In all honesty I wouldn't worry about it. Unless it's a factory 289 hipo or something special it really doesn't affect the value. I went through the same on mine. And for 65 there's no way to know if it's the original block. The 289 used the same casting number for awhile.
BA68 mustang is offline   Reply With Quote
Old 07-13-2014, 08:14 AM   #3
I believe the stamping below the dist. Should match the last numbers in the VIN, and they didn't do that untill '68
Old 07-13-2014, 09:44 AM   #4
Thanks for the reply BA68. The wife was worried about value, this is our first attempt and did not do enough research prior to buying. We are learning a lot. Need to get an idea of its true worth. Posted some pics in my album.
390 engine casting number GarenS390 Classic Mustangs 18 04-08-2013 11:52 PM
2.3 cyclinder heads casting #'s rseibenick 2.3 Mustang 0 01-23-2013 04:47 PM
casting numbers on heads dreamstang 1979-1995 Mustang GT 23 08-29-2011 07:29 PM
Casting Hot Rod Parts at7311 General Car Discussion 2 03-17-2009 12:03 AM
351W black casting snake428CJ 1979-1995 Mustang GT 3 03-18-2006 09:43 AM
05:03 AM
