Ford 9 inch rear drum cylinder torque specs. - Mustang Evolution
Old 07-24-2014, 01:38 PM   #1
Stanglover1966's Avatar
Long time no see
Had to remove the brake cylinder that operates the rear drums to install new studs. There's 2 bolts that hold the cylinder down behind the dust shield. Can anyone provide the torque specs for those 2 bolts?
Pictures:
Name:	ImageUploadedByMustang Evolution1406230659.763170.jpg
Thanks in advance.
Stanglover1966 is offline   Reply With Quote
Old 07-24-2014, 06:36 PM   #2
BA68 mustang's Avatar
I don't know the exact # but snug (25-30ftlbs) should be plenty with a dab of locktite
BA68 mustang is offline   Reply With Quote
Old 07-25-2014, 05:37 AM   #3
ER12883's Avatar
I believe you should be using a lock washer on there. It will be some time before I can check mine, but everything you need to know should be in a shop manual - I can check in mine, but not for a week or so.
ER12883 is offline   Reply With Quote
Need 94-95 specs engine specs blaster_5.0 1979-1995 Mustang GT 0 10-28-2013 09:23 AM
98 ford mustang v6 torque specs Fourloko530 Pre-2005 V6 Mustang 13 01-25-2013 09:56 PM
15 inch or 17 inch rims Vistablue Mustang Wheels & Tires 21 01-11-2013 05:15 AM
3.5 inch or 4 inch tips? 2002Gt 1996-2004 Mustang GT 73 06-19-2011 09:29 PM
Vibration Dampener Torque Specs ridelikehell The Bar 2 02-17-2004 05:39 AM
06:19 AM
