Instrumentation lights - Mustang Evolution
Old 08-03-2014, 08:59 AM   #1
I am attempting to change out the instrumentation lights to LED on my 73 Mustang. I have the directional working as well as one of the speedometer bulbs working. I have checked and the bulbs not working are not getting any voltage. I have cleaned to contacts with electrical cleaner and nothing. Is it common for the circuit board to only work for certain bulbs? Is there away to test it before I buy a new one. Thanks.
mondomustang is offline   Reply With Quote
Old 08-03-2014, 09:53 AM   #2
BA68 mustang's Avatar
All of the bulbs ground through the metal clips that hold them in, clean them up and put a dab of dielectric grease on them, if that doesn't work idk what would be next
BA68 mustang is offline   Reply With Quote
Old 08-03-2014, 02:18 PM   #3
Tyoung68's Avatar
Get a test light and just start probing and see where the power is lost
Old 08-06-2014, 11:48 AM   #4
Commercial Member
matcox83's Avatar
You can check continuity on the circuit board too. I had them in my '66, and they worked fine. I know it's a different setup, but it sounds like you might be on the right track with the circuitry
Old 08-09-2014, 09:51 AM   #5
Well, I changed out the circuit board and the lights came on. Then the next time I tried to turn them on, nothing. The only light working are the 3 that worked before, the directionals and the red mustang on the bottom of the speedometer .now I am thinking it is the headlight switch. Any ideas?
Old 08-09-2014, 10:40 AM   #6
ER12883's Avatar
If it worked, then didn't, I would for sure look around for a loose connection or short before throwing more parts at it.
I had no left turn signal or brake light and replaced the turn signal switch but it didn't help. Turns out that there was just one wire that had pulled loose from its harness up under the dash.
ER12883 is offline   Reply With Quote
Tail lights and marker lights, Painted or Vinyl? michael81 2011-2014 Mustang GT 20 12-02-2011 12:20 AM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
Stop Lights vs. Red Lights bbunt302 The Bar 25 12-11-2005 01:49 PM
Guage lights and ac panel lights steedav6builder Mustang Audio & Video 15 03-11-2005 03:10 PM
FOR SALE: tail lights, head lights, clear corners, tail light covers, dvd, xbox games Zim Mustang Parts for Sale and Wanted 15 12-13-2004 12:45 PM
01:36 PM
