?? brake drum size?.. shoe width and cylinder bore?? ahh - Mustang Evolution
Old 08-07-2014, 11:24 AM   #1
richpickins01's Avatar
ok. so I need new back shoes and wheel cylinders but have been asked.. whether drums are 9 or 10 inch.. the width of shoes and whether wheel cylinders were 0.875 or 0.906 bore? Haven't got clue? My car is a 1966 v8 coupe 289cu if that helps?? any advice much appreciated team
richpickins01 is offline   Reply With Quote
Old 08-07-2014, 04:47 PM   #2
ER12883's Avatar
If you measure the drum, it will be either 9 or 10" in diameter on the inside. Also get a measure of the width of the shoe. Or better yet, bring a shoe in and match it up. Not sure about cylinder, probably best to match that up too.
ER12883 is offline   Reply With Quote
Old 08-08-2014, 03:34 PM   #3
Commercial Member
matcox83's Avatar
Go to one of the websites for Mustang parts. There should be some detail for the party's to help you. I believe you will have 10" drums. 6 cylinders had 9" Are you sure the car is originally a V8? At least, does it have 5 lug wheels? If originally V8 drums will be 10 x 1.75". According to the catalogs the wheel cylinder will depend on build date. Built after 4/15/66 takes the smaller bore. You should look it up yourself to confirm though.
Old 09-02-2014, 01:50 PM   #4
Thanks both. Finally got the pads and cylinders. . got it all off except for the nut around the break fluid pipe into the back of the wheel cylinder is stuck solid! . tried a 10 then a 1/8 then a 3/16. The 10 is too big.. 1/8 too small and the 3/6 too big. eh? what other size is there in between haha
Old 09-02-2014, 03:38 PM   #5
Tyoung68's Avatar
Vice grips and a torch
Old 09-02-2014, 04:04 PM   #6
ok man. on it
Old 09-02-2014, 05:04 PM   #7
ER12883's Avatar
ok man. on it
Keep in mine unless you're replacing or reflaring the tube, you're going to need that nut!
Old 09-02-2014, 05:57 PM   #8
Commercial Member
matcox83's Avatar
Get new lines. They'll never be good again.
Old 09-03-2014, 02:41 PM   #9
oh no.. ok will look to getting some ordered. thanks again all.
Old 09-09-2014, 02:45 PM   #10
Ford 9 inch rear drum cylinder torque specs. Stanglover1966 Classic Mustangs 2 07-25-2014 05:37 AM
Master cylinder bore size? Tyoung68 Classic Mustangs 4 12-29-2013 07:17 PM
Will 1964-1966 mustang drum brake hubs fit my 1971 mustang? meturato Classic Mustangs 1 12-15-2011 01:16 AM
Performance drum brake shoes? mrpjq Classic Mustangs 3 01-16-2008 08:01 PM
Guess Shoe Got 0wn.T **WW** bluemustang The Bar 22 03-07-2005 08:14 PM
10:46 PM
