Only one brake light is working... - Mustang Evolution
Old 09-28-2014, 04:48 PM   #1
Tyoung68's Avatar
Only the passenger sides works i have no power through out the wire and its has completely baffled me. I made some led tail light and both worked before i put them in so the rational me put the regular bulbs back in and still only one side works. Iv swapped the led panels and still only the passenger side works no matter what. All fuses are in tact and iv replaced the brake light switch
Old 09-28-2014, 06:31 PM   #2
BA68 mustang's Avatar
Are all the connections clean? Maybe the ground is bad in the trunk. There might be a junction in that harness in the driver side footwell if you take the kick panel off, I can't remember for sure tho.
BA68 mustang is offline   Reply With Quote
Old 09-28-2014, 06:36 PM   #3
Tyoung68's Avatar
I forgot to say that it is an after market harness but ground is good even hooked one up to the bat and all connections are clean
Old 09-28-2014, 06:38 PM   #4
Hmmm, I think the brake lights run through the steering column, I'd check that plastic connector at the bottom, that always gives me fits in my car
Old 09-28-2014, 11:08 PM   #5
Tyoung68's Avatar
I was looking at that when you said that! I think thats my problem
Old 09-30-2014, 01:20 AM   #6
Ammermeow's Avatar
I had the same problem in my 66. Traced it all the way to a pinched wire in the turn signal cancel switch.
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 10-06-2014, 12:07 AM   #7
Tyoung68's Avatar
Well got a new turn switch and all is working now!
Killing time isnt murder, it's suicide
Old 10-06-2014, 03:39 AM   #8
Ammermeow's Avatar
Crazy right? I messed with the one brake light issue for years thinking it was the connector on the tail lamp itself. Never even considered it was in the steering column.
Old 10-06-2014, 10:21 AM   #9
Tyoung68's Avatar
Yeah well i was looking at my wiring and saw the brakes are operated by the same wire as the turn signals and all the other wires are brand new so I figured it had to be that but it is a pretty crappy design
Only one reverse light works 91MustangNSB 1979-1995 Mustang GT 3 12-29-2013 02:18 PM
Third brake light and license plate light problems bkh1994 Pre-2005 V6 Mustang 20 09-05-2013 08:34 PM
If only, if only Mr Sly 2011-2014 Mustang GT 1 02-08-2012 05:10 AM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
11:46 PM
