Headers or v8 conversion - Mustang Evolution
Old 10-12-2014, 11:11 AM   #1
66strate6's Avatar
Right now I am deciding between getting headers for my inline 6 or getting the conversion kit for either a 289 or 302. I want more power but I would prefer torque over horsepower and I heard headers will help with that. How hard would it be to put a v8 in and how hard would it be to take it out and put the 6 in if I was going to sell it original? If I was to do headers how much more torque will I get, will it be a big difference? How much will the conversion for a v8 be? How much would the headers cost and what brand do you suggest for more torque? The reason I want torque is because I heard straight 6's have low end torque. Thanks so much
66strate6 is offline   Reply With Quote
Old 10-12-2014, 12:14 PM   #2
When people say that 6 cylinder engines have "lots of torque", they are generally referring to the larger truck engines. The 200 cubic inch six cylinder has at least 100ftlbs LESS torque than a 289 V8.
Headers won't even get you close.
If you want to keep the car original, then I would just leave the 6 cylinder in it and put a header and a glasspack muffler and enjoy the car as it is. There is a lot more to swapping a V8 into a six cylinder car than meets the eye and if you take the time to do it correctly, you sure as hell aren't going to want to "undo it" when you sell it.
As far as a price comparison goes, you're looking at several hundred to do the exhaust system on your 6 cylinder and the cost of a V8 swap is going to be a few thousand dollars, at least.
Id look into a Doug Thorley header, if they're available, for your engine. Their designs are known for their low end torque.
Old 10-12-2014, 05:55 PM   #3
ER12883's Avatar
Keep in mind that a V8 has stronger spindles, suspension and other differences to handle the weight and power difference. The engine change is not just dropping in a different engine. Also it's actually possible that selling your car with a properly done v8 upgrade will bring more money.
ER12883 is offline   Reply With Quote
Old 10-12-2014, 06:16 PM   #4
Tyoung68's Avatar
You have to account for the transmission radiator drive shaft and rear end. Along with the up graded suspension and brakes so will be able to stop in a reasonable distance. As far as the header I have one on my six with 2.5ss dual exhaust with flowmasters along with electronic ignition and a shift kit in my c4 and a 8in rear end my car can beat people off the line but thats about it haha so unless you have a decent chunk of change for your swap id say do some things to your six and start the upgrades for the v8 swap like rear end and disk brakes to start
Killing time isnt murder, it's suicide
Old 10-13-2014, 07:33 PM   #5
eubanks.kevin7's Avatar
If it's matching numbers keep the v6. Get it bored and put in dome pistons. Get a bigger cam. Put on a triple Duce carburetor. That should give you a hell of a lot more horsepower and torque. Here is the website for the triple Duce. http://m.summitracing.com/parts/ofy-5970
eubanks.kevin7 is offline   Reply With Quote
Old 10-13-2014, 07:54 PM   #6
Old 10-13-2014, 08:57 PM   #7
Tyoung68's Avatar
Its a l6 not v6 sorry just a little pet peeve of mine haha
Old 10-13-2014, 08:57 PM   #8
Good point.
Old 10-13-2014, 09:01 PM   #9
Tyoung68's Avatar
And depending on the intake style that i take may or may not work. If its the log type then you're pretty much stuck with one carb. If you have the removable intake then you can also look at straight six performance? I think thats the name they have all sorts of goodies for the l6 like cams headers intakes and heads if you want to go crazy.
Old 10-13-2014, 09:03 PM   #10
ER12883's Avatar
I'm still hoping you decide to turbo yours someday - I want to see that!
Old 10-13-2014, 09:04 PM   #11
I thought all 1966 i6 mustangs had a detachable intake
Old 10-13-2014, 09:09 PM   #12
Tyoung68's Avatar
Im not sure about that tbh but that doesn't mean that some one hasn't swapped the head on it or the whole engine!
---------- Post added at 08:09 PM ---------- Previous post was at 08:09 PM ----------
Headers or no headers Cobra2010 Shelby Mustang 27 09-05-2012 08:11 PM
Longtube headers or shorty headers? Stanglover1966 General Mustang Discussion 5 07-29-2012 09:10 AM
Jba 1 5/8 shorty headers (insight on jba headers) go or no go? Swangin_Stangs 1979-1995 Mustang GT 24 01-13-2012 06:15 PM
headers or no headers what do you think 02mach6stang Pre-2005 V6 Mustang 2 06-16-2008 06:11 PM
94-98 Factory headers VS 99-04 Factory headers Herbstang Pre-2005 V6 Mustang 2 08-08-2007 04:53 PM
07:16 AM
