Dash Gauges - Mustang Evolution
Old 10-28-2014, 06:22 PM   #1
sid719e's Avatar
Dash Gauges
I'm having an issue with the gauges on my '65 Mustang. The gas gauge and the temp gauge isn't working. So, I took out my circuit tester (I guess that's what it's called - it lights up when it detects power), put the ignition to On, and when I touch the back of the instrument cluster voltage regulator with the circuit tester (the side with the wires that go to the gauges) all of my instrument panel lights come on and both the gas and temp gauge spike all the way to the right. Also, when reading about the ICVR, it appears that there is supposed to be a ground wire coming from the screw holding it to the cluster. Well, there is no ground wire there. Anyone know what's causing this?
sid719e is offline   Reply With Quote
Old 10-28-2014, 07:52 PM   #2
Aggiesrok's Avatar
The temp gauge could be the sending unit on the intake. It sounds like the gauge works with 12v, I think it only needs 3-5, so 12 will peg it. Seems like your cluster isn't grounded properly. The gas gauge works from the resistance of the fuel sending unit, That wire goes under the sill plate, through the back seat area and under the car to the fuel tank. Since it works by measuring resistance, any bad spots on the wire can cause a problem. so it could the wire or the sending unit in the tank. Make sure the ground is good, then start troubleshooting the rest.
Chevy runs deep, don't step in Chevy.
Old 10-28-2014, 10:25 PM   #3
Mil1ion's Avatar
Send a message via Yahoo to Mil1ion Send a message via Skype™ to Mil1ion
The ICVR puts puts out 5v pulsing power.
It should have a good pulse time
On occasion they eventually fail.
They slow down so much the needle will move back and forth.
Perhaps you touched the wrong part to pin the needles?
How can i help you with this ?
My name is Dennis and I approve this message.
Mil1ion is offline   Reply With Quote
Old 10-28-2014, 10:28 PM   #4
Mil1ion's Avatar
Here's how if works.
First thing is test it.
There isn't a wire per se. ...it's the copper band that is ground as i recall.
Old 10-28-2014, 10:34 PM   #5
Mil1ion's Avatar
See how it works ?
Edit....whoops double post.
Old 10-29-2014, 04:34 AM   #6
sid719e's Avatar
Thanks for all the info. I was just wondering why all of the instrument cluster lights and gauges spiked when I touched the icvr with the circuit tester. I've been reading as much as I can find on these voltage regulators, and from what I've seen, the ones widely available for purchase in stores and online aren't very reliable. This one is less than a year old. I ordered another one that was built by someone and recommended by a lot of folks, so I'll try that one out and report back. Also, I connected a ground, so if any issues were arising from that, hopefully they will stop.
Old 10-29-2014, 12:15 PM   #7
Mil1ion's Avatar
What terminal did you probe and what did you use for ground?
Did you get the correct one for your vehicle?
If you completed a ground with your test equipment. ..the gauges would pin high.
You're looking for pulsing 5v.
Old 10-29-2014, 02:51 PM   #8
sid719e's Avatar
I probed both terminals to make sure I was getting power and power was leaving. I used one of the steel braces behind the instrument cluster as the ground. The icvr was in the car when I got it. The previous owner replaced it earlier this year. That's what happened, the gauges pinned high and the lights came on.
Old 10-29-2014, 09:35 PM   #9
Mil1ion's Avatar
Ground clamp to ICVR case or mount screw.
Apply power to the ICVR using a 9 v battery to power in.
Or a 12v power supply.
Probe power out.
5v pulsing.
I have an OEM Ford ICVR for a 60's Mustang in the garage I'll never use.
IYI.
Apparently years later they made a solid state version.
But there were part number differences over the years.
Looks like tomorrow will be bring in the mustang parts.
I can photograph back to help with pics.
Old 10-30-2014, 04:37 AM   #10
sid719e's Avatar
Well, last night I was playing around with it and it started working correctly. I had to bend the post that sends the power out to the three gauges. Once I moved it, the gauges started working. I have a new icvr coming in, but I will definitely keep you in mind if I want to use an original one. Thanks for the info Mil1ion.
Plasti dip dash/ remove airbag cover dash panel austin0324baird Mustang Paint, Appearance & Detailing 4 05-26-2014 10:59 PM
Problems with dash gauges jacob.a.gasparp 1979-1995 Mustang GT 16 09-29-2012 10:40 PM
added to the pile today - in-dash gauges w/ bezel fast64 Pictures and Videos 6 01-24-2005 11:15 PM
My white face gauges MusclesFromBrussels Mustang Audio & Video 1 10-28-2003 03:18 PM
Nitrous gauges MusclesFromBrussels Pre-2005 V6 Mustang 3 09-17-2003 08:16 PM
05:53 AM
