8.8 rearend swap - Mustang Evolution
Old 11-04-2014, 09:13 PM   #1
Bpolley11's Avatar
8.8 rearend swap
I just picked up an 8.8 differential today to swap into my 68 mustang. Does anyone know what adapter I will need to use the driveshaft I am already using?
Bpolley11 is offline   Reply With Quote
Old 11-05-2014, 12:46 AM   #2
Tyoung68's Avatar
Are you swapping the whole axle?
Killing time isnt murder, it's suicide
Old 11-05-2014, 09:06 AM   #3
Bpolley11's Avatar
Yes entire thing. Click image for larger version
Name:	ImageUploadedByMustang Evolution1415203775.444781.jpg
Old 11-05-2014, 11:57 AM   #4
Tyoung68's Avatar
http://www.hotrod.com/how-to/transmi...l-new-rearend/
It list part numbers at the end.
Why are you swapping rear ends?
Old 11-05-2014, 12:26 PM   #5
Bpolley11's Avatar
Thanks!
Figured I'd go with an 8.8 instead of keeping my 8. My 8 has 2.80 gears and the 8.8 I just got has 4.10 posi and disc brakes
Old 11-05-2014, 01:35 PM   #6
Tyoung68's Avatar
Originally Posted by Bpolley11 View Post
Thanks!
Oh nice. Yeah ill probably get an 8.8 eventually.
Old 11-05-2014, 01:39 PM   #7
bigmac3's Avatar
Thanks! Figured I'd go with an 8.8 instead of keeping my 8. My 8 has 2.80 gears and the 8.8 I just got has 4.10 posi and disc brakes
You're really going to love these. I swapped from 2.80s to 3.50s back in the day in my '66. What a kick in the seat.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 11-05-2014, 04:34 PM   #8
Bpolley11's Avatar
Anyone know if when I swap the differentials if all I have to do is hook the brake line up to the new differential with disc brakes. I was going from drum brakes on the old one.
Old 11-05-2014, 05:01 PM   #9
Aggiesrok's Avatar
If you're on drum before disc, then you will need to change brake lines, fittings are a different size, new proportioning valve and master cylinder. If you have power brakes you should check that also. You will need to change your speedo gear in the tranny to compensate for new ratio and wheel size.
Chevy runs deep, don't step in Chevy.
Old 11-05-2014, 05:04 PM   #10
Bpolley11's Avatar
I could just get fitting adapters though correct? My 68 came with power brakes.
---------- Post added at 07:04 PM ---------- Previous post was at 07:04 PM ----------
What will be different about master cylinders?
Old 11-05-2014, 05:41 PM   #11
Aggiesrok's Avatar
You'll need them for the proportioning valve also, assuming there's room.
8.8 rearend swap with 4:10 gears Sluder4 Pre-2005 V6 Mustang 21 09-15-2013 07:36 PM
explorer rearend swap fordracing63857 1979-1995 Mustang GT 2 11-10-2012 05:21 PM
7.5 to 8.8 rearend swap questions... strawdog Pre-2005 V6 Mustang 6 06-18-2009 03:11 PM
2005 rearend question Johnny D Pre-2005 V6 Mustang 3 02-11-2004 07:19 PM
Rearend parts for 8.8 swap?. slow232 Pre-2005 V6 Mustang 11 08-03-2003 01:37 PM
08:03 PM
