New cam and parts - Mustang Evolution
Old 12-06-2014, 12:12 AM   #1
Tyoung68's Avatar
New cam and parts
Sooooo I'm looking at a cam and I'm wondering if its "needed" to replace the lifters. My head has be completely redone and all mew springs and I'm looking at a comp cam from summit and they have three different ones. One has new springs, lifters, timing chain and gears. The other is just the cam, lifters, and timing gear and chain. And last is just the cam. The first kit is like 250 second choice is 200 and the cam by itself is 133. So my question is are the lifters really that important? Im either just going to get the hole kit or just the cam. The only reason I'm thinking just the cam is because the rest of the engine is pretty much in need of a rebuild machine wise and if I play my Cards right i could get away with not taking my head off which will be a greatly appreciated thing. Anyways to make this long post shot. Do I need new lifters or can i just slap the cam in and call it a day? Its a I6 btw.
Killing time isnt murder, it's suicide
Old 12-06-2014, 02:03 AM   #2
natestang07's Avatar
For that much money I would just do it all at once, give yourself some piece of mind
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 12-06-2014, 05:17 AM   #3
Mlarv5's Avatar
Ask yourself a few questions
When were they replaced last?
Do you want to do this job again because you didn't replace the part this time?
Can you afford to do it now?
I am of firm belief that if I am in an engine I replace any of the parts that I can while I am there. That way I don't have to open it up again for that reason.
If they only have a few thousand miles on them then I would not replace them. If you don't know how many miles then I would replace them.
I would also do the push rods at the same time if you don't know when they were replaced last.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 12-06-2014, 07:14 AM   #4
BA68 mustang's Avatar
I'd get new springs too, if they don't match the cam profile it could end badly, the extra $100 is worth the peace of mind
BA68 mustang is offline   Reply With Quote
Old 12-06-2014, 12:18 PM   #5
Tyoung68's Avatar
New cam and parts
All good points. The springs are only a few pounds difference and were replaced a little over a thousand mikes ago. And i kinda an on a budget im going to swap a v8 in in the relatively new future so im not really trying to put a lot of money into this engine
Old 12-07-2014, 07:59 AM   #6
Commercial Member
matcox83's Avatar
If you don't replace the lifters, you run the risk of wiping or the lives on your new cam. From everything I've ever heard, you should never replace the cam but not the lifters.
---------- Post added at 09:59 AM ---------- Previous post was at 09:59 AM ----------
"Wiping out the lobes"
Old 12-07-2014, 07:18 PM   #7
Tyoung68's Avatar
Yeah i think im going to just get the whole kit
Old 12-08-2014, 07:06 AM   #8
Aggiesrok's Avatar
+1
It's like replacing brake pads without turning the rotors. Your should start new.
While you're in the cam, make sure your heads have screw in rocker studs and not pressed in. It'll save you later from having that done.
Chevy runs deep, don't step in Chevy.
Old 12-08-2014, 12:58 PM   #9
Tyoung68's Avatar
which one do you guys thing would be better? my car has manual steering and power brakes. I already have a vacuum canister.
http://www.summitracing.com/parts/cc...view/make/ford
The only thing i can really tell is the difference between the to is the power band. One is 500-4500 and the other is 1000-5000 which do you think is better power band? My car never is really under 1000 when Im driving and i haven't gotten it up to 5k while driving
and the rocker arms are bolts already
Old 12-08-2014, 03:40 PM   #10
Commercial Member
matcox83's Avatar
Get the power in as soon as you can. The six might not even get to 5k!
Old 12-08-2014, 03:44 PM   #11
Commercial Member
matcox83's Avatar
Here's what I'm running but I have a 2V with a late model head that has big valves and some porting work. Also have the dual out header.
http://classicinlines.com/proddetail...CSC-264-HDP-10
Old 12-08-2014, 07:11 PM   #12
Tyoung68's Avatar
Good point haha. If i were to get one for a 2v would it be okay to run the carb i have for now? Until i can raise the funds for that swap
Old 12-09-2014, 05:03 AM   #13
Commercial Member
matcox83's Avatar
Get in touch with Mike at Classic Inlines. He can let you know. If you plan to do the V8, I don't know if you can justify the extra expense on the six though
Old 12-09-2014, 11:02 PM   #14
Tyoung68's Avatar
Yeah ill probably just get the one form summit. I bought head studs tonight and new pushrods. Should i put new cam bearings in too? Or should i be fine without them
Old 12-10-2014, 04:53 AM   #15
Commercial Member
matcox83's Avatar
I've never heard that you have to replace the bearings unless you have indication that they're bad. Did you replace them the first time you built the engine? I believe it is something best left to a machine shop unless you somehow have the right tools
Old 12-10-2014, 05:57 AM   #16
Tyoung68's Avatar
New cam and parts
I didnt replace them because i was leaving the cam and everything i figured they all wear to together . I have access to the tools Ill just see what the look like and replace if necessary
Old 12-12-2014, 01:42 AM   #17
Tyoung68's Avatar
Im starting to think I'm not going to feel much of a difference in the cam i was looking at. Im looking at either this one Click image for larger version
Name:	ImageUploadedByMustang Evolution1418373422.909612.jpg
ID:	171632Or the 264/264 112 Click image for larger version
Name:	ImageUploadedByMustang Evolution1418373393.473989.jpg
ID:	171631 and here are the base line specs for the car Click image for larger version
Name:	ImageUploadedByMustang Evolution1418373684.238276.jpg
ID:	171633Click image for larger version
Name:	ImageUploadedByMustang Evolution1418373698.839816.jpg
I can see the difference in the specs and kind of understand them. I still want to be able to cruise but with more power. The only problem with the 112* one is the power band goes pretty high and I'm normally driving anywhere from 1500-4500 and i like that the comp cam kit comes with all the rights springs and everything. Also everything engine wise is stock except for the exhaust. I think i just talked myself into the comp cam one haha. But any other impute is appreciated!
Old 12-12-2014, 09:47 PM   #18
Aggiesrok's Avatar
New cam and parts
Cams can be a great mod, but the wrong one that doesn't match the engine components can be a disaster.
My advice is to call Edelbrock, Comp Cams, Crane and tell your engine specs and get cam recommendations. Then make your choice.
Old 12-14-2014, 08:12 PM   #19
Tyoung68's Avatar
Well I got my head studs but no push rods in the mail and i just ordered lifters, cam bearings and a gasket kit from summit. Im going to go with a 264/264-112* hyd cam and 302 valve springs from classic Inlines. Cant wait to get it all and out it in!
Old 12-14-2014, 08:31 PM   #20
ER12883's Avatar
I hate when you only get half of what you need!
ER12883 is offline   Reply With Quote
Old 12-14-2014, 08:54 PM   #21
Tyoung68's Avatar
I know I opened the box and looked through all the paper as if I couldn't feel 12 push rods haha!
Old 12-16-2014, 01:14 PM   #22
Tyoung68's Avatar
Well a little annoyed still haven't heard back from classicinlines about the missing parts. Iv email and called the 7 times and they all went to their full voice mail good thing I payed through pay pal. If I don't here back from them by tomorrow after noon I'm just going to open a claim with pay pal. Which sucks because I was going to buy my cam and new valve springs from them but now I'm not so sure.
On the other hand should have my cam bearings and gasket kit today and lifters Friday. Just need the cam haha
Old 12-16-2014, 04:48 PM   #23
Tyoung68's Avatar
Well they got back to me. Apparently they "sent me an email" saying they are on back order and should be in stock in a few days
Old 01-01-2015, 09:27 PM   #24
Tyoung68's Avatar
Well got everything but the push rods. They are. Chrome moly are those really needed? I can get some from a local parts store and have them in a hour should I cancel the order?
Other news, my coil too a crap. The part that connects to the wire got all corroded and rusted within a year so i ordered DSII from classic inlines
Old 01-01-2015, 10:12 PM   #25
Aggiesrok's Avatar
You've got to wait for a coil, might as well wait for the push rods.
Old 01-01-2015, 10:22 PM   #26
Tyoung68's Avatar
Good point
Old 01-14-2015, 04:29 PM   #27
Tyoung68's Avatar
Well haven't updated this is a while but any way iv pulled my motor to make life a little easier
Name:	ImageUploadedByMustang Evolution1421277648.226352.jpg
And made some tools
For installing the bearings its just a threaded rod with washers and a pvc cap with some tape around it to center the bearings Click image for larger version
Name:	ImageUploadedByMustang Evolution1421277712.737066.jpg
And a small (I think too small but my printer can print this big) degree wheel I Used auto cad to make it then just put it between some plexiglass and mdf Click image for larger version
Name:	ImageUploadedByMustang Evolution1421277880.151401.jpg
Now I'm trying figure out how to degree the cam. But cant really figure it out. Well Kinda. So I assume I start off at TDC with the the dots lined up. And then find true TDC by using a piston stop. Then set wheel to zero. After that I'm lost haha. Im suppose to measure lift but don't really know what to do with the numbers. My old auto teacher has open shop tomorrow night and I'm going to see if I can drop by and have him help me. And iv watched hundreds of videos on YouTube about how to degree cam but does anyone know an easier way of doing this?
Old 01-14-2015, 07:38 PM   #28
Tyoung68's Avatar
Also did a lil hand porting and polishing. Still need to clean up a few areas Click image for larger version
Name:	ImageUploadedByMustang Evolution1421289447.576437.jpg
ID:	173566Click image for larger version
Name:	ImageUploadedByMustang Evolution1421289430.957349.jpg
Old 01-15-2015, 11:28 AM   #29
Commercial Member
matcox83's Avatar
I had mine done but the process doesn't seem difficult, just tedious. Here's a link from Classic Inlines that describes it in good detail, two different techniques. I don't think it's supposed to be "easy" though!
http://www.classicinlines.com/CamDegree.asp
Old 01-15-2015, 11:08 PM   #30
Tyoung68's Avatar
I never realized how I was suppose to ****** or advance my cam.. I thought I was just going to have to more the chain and gears. So if i read that article right i need the eccentric bushings? Sense the cam had a dowel pin? I guess ill give classicinlines a call tomorrow
Old 01-16-2015, 05:58 AM   #31
Commercial Member
matcox83's Avatar
If you get the double roller timing chain you can use the sprocket to index. Otherwise, I think you use an offset keyway. If you get a clay smith cam you have to advance. Many others are ground with the advance built in and you install straight up
Old 01-16-2015, 09:22 PM   #32
Tyoung68's Avatar
Well I ordered the double roller chain hope to have it by Tuesday/ Wednesday and then I can go to auto on Thursday and my old auto teacher will help me degree my cam. Man i cant wait to get my car back!!
Old 01-17-2015, 01:11 PM   #33
Commercial Member
matcox83's Avatar
Sounds great. You'll be able to feel the difference.
Sent from my SM-T700 using Mustang Evolution mobile app
Old 01-26-2015, 10:43 PM   #34
Tyoung68's Avatar
Well iv got her almost back to getter my torque wrench was acting up so i ordered a new one so i can get my head torqued down correctly. Other than that it should be good to go! Just finished up a fresh coat of paint Click image for larger version
Name:	ImageUploadedByMustang Evolution1422337389.147837.jpg
Old 01-27-2015, 04:40 AM   #35
ER12883's Avatar
Nice!
For Sale: Complete cam kit for 3.8 / 3.9 Mustang v6 and other parts ANS Mustang Parts for Sale and Wanted 4 11-03-2014 02:14 AM
Where can i find good part engine and modified parts and custom parts? searbhreathach General Mustang Discussion 3 03-03-2010 07:29 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
05:35 AM
