Welding welding welding well sucks - Mustang Evolution
Old 12-18-2014, 09:50 AM   #1
Mlarv5's Avatar
OK I feel almost better. I am in the middle of replacing my quarter panel skin. I had to repair my wheel wells around the flange area. As soon as I hit it with the Mig welder it blast a hole in the steel. I bought a Lincoln MIG 140C it is set up correctly I checked and doubled checked it then I called Lincoln to make sure. I have the correct Argon CO2 mix as well. So what am I missing do I just have to work though it any body workers out there.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 12-18-2014, 10:18 AM   #2
I have that same welder. Try turning the heat down a bit and increase the wire speed by a bit. After you learn the basics, welding is all about practice, practice, practice. Use the old quarter panel to practice on and to figure out the correct settings for the welder.
You'll get it Mlarv, just keep practicing!
Old 12-18-2014, 01:14 PM   #3
Mlarv5's Avatar
I know practice. I need to get the wheel well flange done today or tomorrow cause the skin is being put on Saturday during my class. I have the welder set on "A" and wire feed set to 3 using .025 wire. I am thinking I might switch to .023 wire which means I need a new sleeve and tension roller. I will talk to the instructor and bring the welder with me to see what I can see.
Thanks
Old 12-18-2014, 02:31 PM   #4
fstbck70's Avatar
Region: Nebraska
Are you welding good steel? The wheel well is new you said but what about the piece you are welding to? It's hard to get a good bond with crap metal
fstbck70 is offline   Reply With Quote
Old 12-18-2014, 02:43 PM   #5
Tyoung68's Avatar
My voltage is usually up to high when the happens to me or my wire feed speed is to low
Killing time isnt murder, it's suicide
Old 12-18-2014, 02:54 PM   #6
Mlarv5's Avatar
Quarter panel skins are new wheel well is old I have ground down to bare steel on the inside and outside of the wheel well. I will get it I am sure
Old 12-18-2014, 05:22 PM   #7
BA68 mustang's Avatar
My neighbor is a machinist, whenever he has run into a problem like that he puts a cold wet rag on the other side of the metal to absorb the heat, if that doesn't work the steel is probly too rusted to weld
BA68 mustang is offline   Reply With Quote
Old 12-19-2014, 06:08 AM   #8
DaddyO's Avatar
Yep, turn the heat down. I'm no welder but I learned a lot when I put new floor pans in. I too blew some holes through the metal until I got the setting correct. Like anything else...practice practice and patients
DaddyO is offline   Reply With Quote
Old 12-19-2014, 11:16 AM   #9
Tyoung68's Avatar
Or your spending to long in one spot causing it to melt
Old 12-21-2014, 05:52 AM   #10
Mlarv5's Avatar
Well got the answer to my problems on this.
I was using the schools welders and never really did have a problem with them. I asked the instructor about the welder I have and what I was doing wrong and he laughed. He said the wheel housing and the area I was welding on was really thin and rusted, The more rust I removed the thinner it got so I was in a no win battle. He looked at the welds and said considering what I was up against I did a good job
I have some spot weld to do in the same area but it should not be as bad because there is a lot of new steel to weld to.
Quarter panel welding?? 1faststang Classic Mustangs 6 08-29-2011 06:09 PM
Dual Welding AA-12 Shotgun Brent Pictures and Videos 4 05-17-2011 10:07 PM
Welding axle tubes? systemdz 1996-2004 Mustang GT 3 01-17-2011 11:03 AM
Welding is Winning the War at Iraq bluemustang The Bar 1 03-28-2007 11:53 AM
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
07:03 PM
