New gears - Mustang Evolution
Old 01-14-2015, 08:05 PM   #1
BA68 mustang's Avatar
New gears
While I'm waiting for my motor to come back from the machine shop I've been kicking around the idea of dropping in a new ring and pinion set along with a LSD. My question is what are your recommendations on ratios? It's a warmes up 289 backed with a c4 that rarely sees the highway. I was thinking 3.55s. What are you guys running? It has the stock 2.79 granny gears in it now
BA68 mustang is offline   Reply With Quote
Old 01-15-2015, 06:20 AM   #2
DaddyO's Avatar
When I swapped out to a 9" reared I put in 3.50 gears from Strange engineering and 11" disc brakes to help stop. Works for me. Good luck Click image for larger version
Name:	ImageUploadedByMustang Evolution1421327965.666714.jpg
DaddyO is offline   Reply With Quote
Old 01-15-2015, 06:21 AM   #3
DaddyO's Avatar
When I swapped out to a 9" rearend I put in 3.50 gears from Strange engineering and 11" disc brakes to help stop. Works for me. Good luck Attachment 173587
Old 01-15-2015, 07:58 AM   #4
Thanks for the input, what trans do you have in it
Old 01-15-2015, 10:06 AM   #5
DaddyO's Avatar
Its a c4 super street fighter built by TCI. It has a manual valve body and I'm using a hurst quarter stick shifter. The 347cu in has about 400+hp. I tried to build it so it wouldn't break down and its holding together quit well. 12.9 seconds in the quarter at 101-103 mph. Gets a little shakey above 110 but I seldom go there. Click image for larger version
Name:	ImageUploadedByMustang Evolution1421341411.749283.jpg
Old 01-15-2015, 10:22 AM   #6
Damn hahahaha, hopefully I'll be there one day, how does it drive in the highway? Do you know what rpm it turns at 65 ish?
Old 01-15-2015, 06:30 PM   #7
ER12883's Avatar
I found a website once that you enter in your tire radius, axle ratio and trans gears and it tells you what rpm you'll be running at. I'd start by googling "rpm calculator" or something like that. Or it's just fairly easy math if you know those things.
ER12883 is offline   Reply With Quote
Old 01-16-2015, 04:55 AM   #8
I'll google it hahaha, give a lazy man a hard job and he'll find an easy way to do it
Old 01-16-2015, 01:10 PM   #9
BigpapaDean's Avatar
I've had 3:55's in my 3 past mustangs. It's a perfect middle ground for light to light and highway. I plan eventually to install some in my 67 with an LSD.
BigpapaDean is offline   Reply With Quote
Old 01-16-2015, 03:17 PM   #10
DaddyO's Avatar
Something like this Click image for larger version
Name:	ImageUploadedByMustang Evolution1421446631.175208.jpg
ID:	173646Click image for larger version
Name:	ImageUploadedByMustang Evolution1421446656.839724.jpg
ID:	173647Click image for larger version
Name:	ImageUploadedByMustang Evolution1421446669.206926.jpg
Old 01-16-2015, 05:12 PM   #11
I ordered 3.25's to be on the safe side, thanks for the input I'll let you know how it goes together
Old 01-21-2015, 05:05 PM   #12
I pulled the center section out over the weekend (I almost broke my wrist in the process) and got it blown appart and reprainted, now waiting for parts to come in Click image for larger version
Name:	ImageUploadedByMustang Evolution1421885129.095139.jpg
Old 01-29-2015, 04:52 PM   #13
The center section went together like a dream, I had a little trouble setting the gear mesh but after a couple hours of fiddling it's all set up and back in the car.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:45 PM
