Vacuum lines on brake booster. - Mustang Evolution
Old 02-15-2015, 09:28 PM   #1
Aggiesrok's Avatar
I replaced master cylinder and brake booster a year ago. Brakes work, but don't seem to have the power that they should.
Lately, noticed an axle seal leak into the rear drum. So in the process replacing the seal and cleaning up drum. I noticed in the Mustang Shop Manual that they show using both vacuum ports on the check valve for the brake booster with am automatic.
So are both lines supposed to be hooked up to the intake for vacuum? Never noticed this difference before.
Chevy runs deep, don't step in Chevy.
Old 02-15-2015, 11:48 PM   #2
Tyoung68's Avatar
When I bought my booster kit it just came with a valve with one port on it
Killing time isnt murder, it's suicide
Old 02-16-2015, 07:17 AM   #3
Aggiesrok's Avatar
Mine has the extra port with a cap on it. Click image for larger version
Name:	ImageUploadedByMustang Evolution1424096194.737936.jpg
Puzzling.
Old 02-16-2015, 09:25 AM   #4
Commercial Member
matcox83's Avatar
I may be easy of from what you are asking, but the circled component in the drawing is the fitting on the booster. The house with clamp comes from the intake manifold. The other hose on an automatic goes to the vacuum shift modulator. Sorry if I got the question wrong.
---------- Post added at 11:25 AM ---------- Previous post was at 11:25 AM ----------
"Way off"
Old 02-16-2015, 11:38 AM   #5
Aggiesrok's Avatar
I've got the large booster hose connected to the intake. I've got the tranny hooked to the intake. I'm not sure what the other connection on the brake booster is for.
I thought for a vacuum canister, but were those installed as stock. Also if that's what it's for, why would you connect to the intake?
Old 02-16-2015, 01:53 PM   #6
Commercial Member
matcox83's Avatar
I agree with you, that's just how it looks in the diagram. Is there a vacuum diagram in the manual that shows where the factory put the modulator hose?
Old 02-16-2015, 02:07 PM   #7
Aggiesrok's Avatar
I'll check when I get off work. But it seems like on the original manifolds they had a nipple for the C-4. But maybe not. I wonder if the booster would behave differently with the tranny hooked to it in line with it?
Old 02-16-2015, 02:20 PM   #8
Commercial Member
matcox83's Avatar
It's just kind of a signal to the modulator. As long as your vacuum is good, I don't think it would have an effect. Capped off is probably the same result. Just make sure you have a good cap on there. If it's brittle it might be leaking.
Old 02-16-2015, 02:20 PM   #9
Tyoung68's Avatar
If it helps I just bought a thunder bird with power brakes and it has that dual check valve and only one line is hooked to it and it is an auto
Old 02-16-2015, 03:48 PM   #10
Aggiesrok's Avatar
Thanks, I think it's the same difference. During production is was cheaper and faster to uncap a brake booster check valve for an auto instead of adding a nipple to the intake manifold.
So I guess I'm good. Thanks again.
Brake Booster Vacuum Hose Tyriqq 2011-2014 V6 Mustang 9 04-10-2014 02:47 PM
Replacing vacuum lines with rubber lines SueK Pre-2005 V6 Mustang 0 10-15-2013 06:59 AM
I have a 1988 Mustang 2.3 litre and my tranny lines leak, are they called oil cooler lines? keandre General Mustang Discussion 3 03-31-2010 12:59 PM
vacuum lines 04TRV6 Pre-2005 V6 Mustang 9 02-05-2010 10:40 AM
Vacuum booster Black Panther Pre-2005 V6 Mustang 2 02-12-2007 09:45 PM
07:59 PM
