68 289 timing question - Mustang Evolution
Old 03-06-2015, 02:43 PM   #1
curt68's Avatar
So I'm trying to set the timing on my 68 289. My question is it necessary to remove the vacuum line from the distributor while lining up the mark with a timing light? And if so, why?
curt68 is offline   Reply With Quote
Old 03-06-2015, 03:02 PM   #2
ER12883's Avatar
Yes. You are trying to set initial timing. The distributor uses the vac signal to advance the timing when you hit the gas. This screws up your reading. You probably have to plug the hole so you will still be able to idle with the hose off.
ER12883 is offline   Reply With Quote
Old 03-06-2015, 03:13 PM   #3
curt68's Avatar
Thanks, there are 2 vacuum connections on the distributor , the hose that is connected now is on the connection nearest the radiator, the other connection is open. Does that sound correct? What's the other connection for ? Retardation of the timing?
Old 03-06-2015, 07:04 PM   #4
Aggiesrok's Avatar
Post a pic. Not sure why there are 2. It's only to advance the timing as already mentioned.
There should not be any open vacuum connections.
Chevy runs deep, don't step in Chevy.
Old 03-06-2015, 07:40 PM   #5
ER12883's Avatar
Yeah I agree. With it running, you can put your finger on it to see if there is vac. Is it aftermarket distro/who makes it?
Old 03-06-2015, 08:29 PM   #6
curt68's Avatar
Name:	ImageUploadedByMustang Evolution1425698887.695067.jpg
ID:	176860 is factory distributor as far as I know
Old 03-06-2015, 10:14 PM   #7
That distributor is from a 70-72 F-series truck. The vacuum pot not only advances the timing but will ****** it as well. That one nipple that is disconnected is the one that retards the timing, so it is connected correctly for your application.
I recommend replacing the vacuum advance on that distributor to one that has a single vacuum line that only advances the timing.
67 289 dipstick question Joshy Classic Mustangs 14 02-25-2015 02:56 PM
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
302 timing set on standard 289 66Hardtop289 Classic Mustangs 2 10-14-2011 10:29 PM
1966 mustang 289 part question? raedford General Mustang Discussion 3 03-01-2010 03:41 AM
Timing question damighty5.0 1979-1995 Mustang GT 12 05-22-2006 04:23 PM
02:05 PM
